View Full Version : pro boat inpulse newbie question.....
stuey4
05-30-2012, 10:32 PM
hey everyone! I ordered my new impulse 31 that should be here tommorrow, just wondering what is the best prop size for this boat? i wil be running 5000mah 20c lipos. is this a decent battery choice for this boat? this will be my first rc boat!
JimClark
05-30-2012, 10:48 PM
look in the RTR Impulse section loads of info there
roadrashracing
05-31-2012, 02:21 AM
I would get batteries with a higher c rating, I run 25c and a little more prop draws a lot of current. Don't run batteries down to low, 4-5 min is what you will get for run time.
nokiaprinter
05-31-2012, 02:07 PM
try 42x55 or m445 make sure you upgrade the connectors to 5.5mm or above thou
BERTBORDEN
07-04-2012, 06:32 PM
Should I change the connectors on the batteries and the motor/esc or just the motor/esc?
Stephavee
07-05-2012, 11:01 AM
x2 on that! i run a m445 and love it...i have the stock motor connectors but run all 5.5s on my bats. also re-do the water cooling so that the esc is the first to get the cooling water...they need to be cooler than the motors do!...have fun this will make a great "first" boat....and down the rabbit hole you go!
d.a.v.e
07-05-2012, 11:03 AM
Both should be done if your thinking of that big of a prop. I also swap out the stock tubing for a larger diamiator tube that allows more water to get though. This seems to be good for reducing temps 5-10 degrees depending on water temps.
Stephavee
07-05-2012, 10:06 PM
http://forums.offshoreelectrics.com/showthread.php?29608-Overtemping-problems
