View Full Version : Twins or not.
SJFE
04-30-2007, 10:47 PM
Ok I need some opinions. I picked up some spare hardware and now I'm considering going twins in the MM. Since I am in no hurry to get it in the water I can drag the build out and nickle and dime it. I would run Hex120s and thinking low cost lipos or 10 Nimh per motor.. Well guys...Lemi have it:)
Doby
04-30-2007, 10:53 PM
I'm re-thinking the twins and triples on the BlackJack, is the MM about the same size??
SJFE
04-30-2007, 10:54 PM
Way bigger Doby. It's 5 inches longer and almost 4 wider. 30 x 11
Doby
04-30-2007, 10:55 PM
Then it would be more stable , go for it ! POWER:D :D :D
hammertime
05-01-2007, 01:24 AM
i think it would be sweeeet...and fast....it def has enough room.....i think it would be worth it and it probly hasnt been done or hasnt been done very often but all in all i think you should do what yuo want.....i think 90% of us would love to seen twins but thats up to you in the end
saleens7
05-01-2007, 06:23 AM
go for the twins...
Eyekandyboats
05-01-2007, 07:50 AM
i think you should do twins. 3s2p per motor use like L series motors in the boat and use it for just straights.
Doug Smock
05-01-2007, 08:16 AM
Sorry wrong thread!!!
avengersteve
05-01-2007, 10:44 AM
im going to encourage it, mo power!
SJFE
05-01-2007, 12:16 PM
Ok now for motor selection:cool:
hammertime
05-01-2007, 05:15 PM
well fiego hadnt done ya wrong yet
SJFE
05-01-2007, 05:59 PM
Yeah that part is a no brainer...its the size and winds I am debating Sir.
Eyekandyboats
05-01-2007, 06:10 PM
L series .
hammertime
05-01-2007, 11:39 PM
well i would say 2 8xl would be good.....wouldnt you need less torque with twins
SJFE
05-01-2007, 11:43 PM
L hu Mr Shaw.. Are you implying I am going to need more rpm than the XL?
Eyekandyboats
05-02-2007, 08:21 AM
is fast better?
the diffrence between the L and XL is kinda minimal. and you get more rpm out of it as well.
i have a friend who ran a P setup with a 10L and won most of his heats he ran in. he may just be a good driver or everyone else sucked.
but you know.
SJFE
05-02-2007, 01:03 PM
I'll give them a shot. I havent used the L series yet so it will add to my knolege base @ best. I'm thinkin a set of 8s..@ just over 3k. Start out on the 40mm prop.
Mich. Maniac
05-02-2007, 07:37 PM
I personally feel twin is where speed is, obviously you can run higher rpm less voltage with double power. keep that nose way up in the air and just your a$$ end in the water... prop walker
SJFE
05-02-2007, 07:44 PM
I was thinking about the placment of the internals today. Keeping every thing tward the back is going to be a priority. I am gooing to leave as much of the tunnel area free as possible for moving batteries around. I dont want more than a few inches of stuffing tube. Low profile carbon fiber motor mounts will be the best bet I am thinking.
