View Full Version : Patron Saint - Twin Mono
bikenewby
05-23-2012, 12:27 PM
:biggrin: 7712677127771287712977130
bikenewby
05-23-2012, 12:28 PM
7713177132
Make-a-Wake
05-23-2012, 12:30 PM
WOW! What is that, 48-50" long? Looks like a pair of 5692's too?
Great lookin' ride there!
bikenewby
05-23-2012, 12:38 PM
It's 51" hull running twin 5692 540KV.
Actually, it was a result from following numbers of your inspiring posts here. :thumbup:
Still under tuning though...
Make-a-Wake
05-23-2012, 12:41 PM
Thanks for the compliment! You run it yet? Whats the voltage........12s?
bikenewby
05-23-2012, 01:31 PM
Only several runs so far. It was running quite wet though. I guess because of two sets of 12s 5000mAh. Total weight was 35lbs. Top speed around 53mph(gps) but the amp drawn was reasonable (90amp peak - each). Going to try with 4000mAh this weekend and play around with COG and struts angle. Any advice is very welcome... :welcome:
Make-a-Wake
05-23-2012, 02:41 PM
Woah! Must be running wet at only 53 mph.............your cog should be around 28-30% from transom, stingers should be neutral or even a tad positive. What props? Surely you can spin a couple of x457-x460's.
Drax21
05-23-2012, 05:40 PM
That is a sweet looking boat. I'm thinking of getting one of these next. Now that I have seen the room inside.
Mattwarner
05-23-2012, 06:00 PM
Wow! I considered one of these but went for another 46" mono going to be running a single 5692 on 12s, make sure you post some vids!
Drax21
05-24-2012, 05:19 AM
Is it wooden inside? I can't see any fiberglass
bikenewby
05-24-2012, 11:39 AM
All fiberglass. The rail is made of epoxy. The only wooden part is transom reinforced.
bikenewby
05-24-2012, 11:41 AM
Thanks Make-a-Wake. Will try this weekend. The props used are pair of x665. Is it too big? I think for twin, choices are very limited. :confused2:
bikenewby
05-24-2012, 12:01 PM
For the 46", you may want to consider this...
77183
Not mine though. This one runs with twin 5698. I think twin mono setup may not be as speedy as expected (or may be just on my setup). :doh: However, the run time is very very good.
bikenewby
06-09-2012, 01:20 PM
Hi guys,
Just to update... after following suggestions and play around with strut angle, cog, reducing lopo weight, and switching prop direction, the boat no longer running wet now. Actually...even need to adjust the trim tab to get the nose down. Most important change was switching prop direction from outward turning to inward turning. This make the whole boat lifted from water (especially the nose) and gain more speed. Thanks to folks on the Prop Talk forum for pointing this out... http://forums.offshoreelectrics.com/showthread.php?34453-Counter-Rotating-Props-Direction-for-Offshore
The amp drawn is higher now but considering size and weight of the boat comparing to speed (61 mph... 98.3 kph), I think for me it's good enough to celebrate... :beerchug:
bikenewby
06-09-2012, 01:21 PM
78523
keithbradley
06-09-2012, 01:44 PM
Beautiful!
I have considered doing one of these multiple times but never pulled the trigger.
Yours looks great. The height of the prop relative to the bottom of the hull caught my attention, but I guess it must work well?
I've never done a twin mono so I've never had the chance to see how well that works. Sounds like you have it figured out though.
Take some video if you can...nothing cooling than a big mono IMO!
bikenewby
06-10-2012, 12:47 AM
Beautiful!
Hi,
Thanks for the complement. Yes, the stingers position are quite high relative to the bottom but there wasn't much of a choice due to shallow V shape and I'm trying to keep 2 props stay away from each other.
This make the boat ran quite wet initially, especially with outward turning prop setup. So I moved the batt to the back to keep cog at around 25% from transom. And with inward turning setup, it ran quite well now. The boat transom is still not totally lifted (only up to prop position) but it ran quite nicely with nose up and only some small area of transom in the water. :rockon2:
Will try to take some vid but need to look for a cameraman first. :biggrin:
Jedi Master
06-10-2012, 06:46 AM
Wicked build, can't wait to see some video!
bikenewby
06-17-2012, 10:46 AM
Ok... update for this week. Just ran the boat today with some vid (badly) taken. I'm still having no luck on cameraman. Also don't want to hold the camera myself during run. So... here is the best I can do... a kind of fly-by video. :biggrin:
http://www.youtube.com/watch?v=dA42DHhbem8
Top speed is still consistent (98.3kph = 61mph). However, as I try to lower the nose lifted by lowering down the stinger angle and trim tab, the boat is now porpoising. Anyone know how should I fix this porpoising problem? Should I lowering down the trim tab and stinger? Or should I move CoG a little forward? Any advice/recommendation would be very appreciated. Note that the stinger angle is still about 2-3degree positive and the trim tab is about +5 degree...
The boat still ran a little wet but a lot improved comparing to previous outward turning setup. Here is the vid of her maiden run. Top speed was around 85kph(~53mph). Please don't mind the spoken language...It's my native tongue.
http://www.youtube.com/watch?v=n5ytLXpPpeU
7917279173
bikenewby
07-30-2012, 11:51 AM
New video clip... :smile:
http://www.youtube.com/watch?v=SlK9r8xaTfc&feature=share
twissted
01-25-2013, 01:16 PM
Graet boat! I my try something like this soon. I'm looking at the Centralrc marine 60" hull. Great build.
DK535
01-25-2013, 04:29 PM
Love the last vid!!! It's screaming!!! Nicely done
bikenewby
01-25-2013, 08:44 PM
Thank you very much. It has been out of water for a while now.
Good luck with your build. Don't forget to post video... :smile:
Uncle Vinnie
03-09-2013, 06:36 PM
Glad I came across your tread, and I must say that's an awesome looking boat.
SpeedFreak_86
03-10-2013, 09:50 AM
Nice job
bikenewby
03-11-2013, 12:21 PM
Thanks guys... :biggrin:
adam777
03-21-2013, 03:35 AM
Nice job, I like this boat. It's really awesome. video is also nice.
Make-a-Wake
03-21-2013, 10:54 AM
Whoa, really running well now!! Did you move your COG back?? You may wanna try one run with the props reversed
bikenewby
03-25-2013, 02:11 AM
Hi, Thanks. The boat ran better now with inward turning props setup. I also move CG toward the back as much as I could, :)
