View Full Version : converting my JAE .12 rigger kit into electric
crazyprophead
05-23-2012, 08:03 AM
hello everyone,
i changed my mind after completing 70 % or so to convert it to electric.
im putting in a xk3665-B-2300kv motor on a 4s
77112771137711477115 77111
crazyprophead
05-23-2012, 08:16 AM
77122771217712377120
i had to,
cut the shaft tube
cut the bulkhead
glue in a new bulkhead out of 1/16 ply to stop any small amount of water from getting to the receiver, (that might come through the shaft tube)
glue in 3.2mm plywood spacers to make the motor mount fit snug
and cut out the old engine wood blocks, this was done by first drilling in to it, then using a dremel bit in the drill press as a makeshift mill.
crazyprophead
06-05-2012, 02:10 AM
78067780687806978070
hull finished and ready for finishing
crazyprophead
06-05-2012, 02:21 AM
7807278073780747807578071
it turned out pretty nice, i designed the catch on autocad which allows for 4x 2200 2s packs in series & parallel to give 4400 4s.
And the overal weight is 1700 grams.
crazyprophead
06-05-2012, 02:25 AM
78078780797808078081
quite a snug fit but it fits, had to solder the esc directly to the motor becauses 5.5mm bullets were to big.
crazyprophead
06-05-2012, 02:43 AM
http://www.youtube.com/watch?v=OnWB4LIvIuU&list=FL4OYHWewMJLjK8JuGLJpfHQ&feature=mh_lolz
crazyprophead
06-11-2012, 10:13 AM
http://www.youtube.com/watch?v=kU5ApJ738kM&feature=channel&list=UL
