View Full Version : cc1555 1650k motor
hpipro4
05-23-2012, 01:18 AM
SOLD...............thnx for looking
m4a1usr
05-23-2012, 09:37 PM
Are you sure thats a Castle motor? Looks like a Neu to me. Worth every bit of $100 if its a genuine Neu.
John
hpipro4
05-26-2012, 10:23 AM
i thought castle n neu were the same? how can u tell?
m4a1usr
05-26-2012, 12:20 PM
A couple different ways. CC motors (40mm and larger) have a front bearing plate that is attached with 3 screws. Neu motors with a front bearing plate that screws in to the can have 4. Also CC motors are sealed with the exception of the A/C version of the 1717. So if your motor has holes in the front and back of the motor its a Neu. And look at the rotor. A CC rotor is wrapped in light green kevlar. A Neu rotor has no wrapping. Probably the biggest give away that your motor is a Neu is look at the very front edge of the motor. It has a slight taper in the diameter. At least 5 of my Neu's have that feature. None of my CC do. Castle built motors with Neu Engineering help. Both make excellent motors. Neu and Castle have different product lines and are not the same company.
John
hpipro4
05-26-2012, 05:47 PM
it does have holes on front and back. thanks for clarifying!
Make-a-Wake
05-26-2012, 07:33 PM
I believe this is your motor:
http://www.atlantahobby.com/Store/pc/Neu-1515-2-5D-Finned-465p7183.htm
hpipro4
06-27-2012, 03:09 AM
still have the motor........
Brushless55
06-27-2012, 12:31 PM
How much use on this motor?
Thanks
hpipro4
06-28-2012, 02:23 AM
i used it for a few mins on my vanquish using 6s with the t180 esc. lmk
Alexgar
06-28-2012, 09:31 PM
So a 6 s motor on what prop
hpipro4
06-29-2012, 02:07 AM
x642 i think....motor is in perfect condition i just dont need it. if ur worried about my feedback....here http://www.rctech.net/forum/itrader.php?u=50021&iv=1
hpipro4
07-04-2012, 02:32 AM
awesome motor here!!!
hpipro4
07-12-2012, 02:13 AM
bump
Brushless55
08-07-2012, 12:05 AM
Money being sent per offer... :tiphat:
