View Full Version : Swordfish PC Programming Help
clarkm
05-21-2012, 09:27 AM
Anyone had trouble installing the software for the Swordfish esc programming.
1. I can't get it to link to a com port.
2. If I find a com port that seems to be connected to esc I get a "Timed out error message" and can't get version when I try to upgrade firmware or do anything?
can Anyone tell what I'm doing wrong or how to fix?
siberianhusky
05-21-2012, 09:47 AM
I run vista on my laptop, I had to log in as admin at first to get access the com ports with the software, I changed the permissions so a normal user could access everything, for some reason for me when it was installed as admin it never gave proper permission for anybody else to access the hardware even though you could start the program.
No idea why.
It's under the properties when you right click on the program icon (not the shortcut on the desktop). Give users full permission.
Try it logged in as admin first to make sure this is the problem.
clarkm
05-21-2012, 11:32 AM
It looks like all users have full permission, my laptop shows it linked to com port 9 (com9) I don't have a com port 9?
clarkm
05-21-2012, 01:39 PM
WOW! Reading the thread above this one it looks like I may have a bad USB Linker! E-mail sent.
hydroman2112
05-21-2012, 03:26 PM
i know this might sound dumb but did you make sure colors on usb match colors of plug
clarkm
05-21-2012, 05:46 PM
Actually I did not notice a color match-up but I thought I might have it wrong and tried both ways. I do get a red light on usb and Green light on esc so I assume that is the correct way but I'll double check when I get home.
hydroman2112
05-21-2012, 07:00 PM
i hooked mine up and i see the red on usb and green esc sw240hv when selected comm i could open settings blue dot on screen goes from blue to green; green light on esc goes off
clarkm
05-21-2012, 10:23 PM
THANKS GUYS I GOT it FIGURED OUT HAD TO REASIGN COM NUMBER.
Now I have a question about the throttle range numbers were does it com from and is it this some we should change?
hydroman2112
05-21-2012, 10:37 PM
dont know about that yet
hydroman2112
05-21-2012, 10:40 PM
think mine says 562
clarkm
05-22-2012, 06:16 AM
think mine says 562
Mine is at 600. Just wondered what this number means and we are able to change it in the PC programing. I see nothing in manual about what it should be so it just bugs me!
hydroman2112
05-22-2012, 08:36 AM
did u where it shows 8 khz lower left corner i beleive that is factory set im going to try and find out about throttle setting
