View Full Version : Blow Esc????
Big Lebowski
05-18-2012, 09:11 PM
How do you know when your esc has failed? No beeps when i turn on boat, only steering and no throttle. 45 a 1800kv 4s2p 25-50c 6000mahs. When i towed boat in temp on esc was 100 boat sat in the water for 15 mins before i got it in. Any advice would be appreciated. Thanks!
lenny
05-18-2012, 09:43 PM
Pull water line off motor that go's to the esc,
And see if you can blow though it.
If its not block you may be in luck,
Than try and reset or bind the tx to rx.
JimClark
05-18-2012, 09:58 PM
The 45 Amp (Proboat)? On an 1800kv motor? probably a bit much for that ESC to handle
JimClark
05-19-2012, 05:14 PM
This is not the For Sale Forum if you have something for sale then list it in the FS Forum this is a discussion.
Two posts have been deleted
JimClark
05-19-2012, 05:18 PM
Go to the FS Forum if you are looking for a ESC not here
How much? I really don't need it. I have a seaking and Leo setup. Thanks
76802 heres the pic i promised
Big Lebowski
05-19-2012, 09:48 PM
Thanks Dana
Do you need a pic of a series and a parallel battery wiring?
Big Lebowski
05-20-2012, 04:44 AM
Yes parallel please. Can you also take a picture of your battery end setup. Thanks again dana
Big Lebowski
05-20-2012, 05:30 AM
What kind of remote is good?
tactic remotes work well.
heres a series and a parallel battery wiring setup
pic 1 is series. pic 2 is parallel
7683076831
pic 1 uses two 2s packs to make 4s1p
pic 2 uses two 4s packs to make 4s2p
