View Full Version : 5s lipo on motley crew .
belltec50
05-18-2012, 08:11 AM
Im a noob here,I have a motley crew,all stock with a 42/55 prop balance race prep has been done and 5.5 bullets.I want to put 5s lipo on it ,and i have a ccbec laying around. does the batteries need to be in series or parallel.thks for your help.
05-18-2012, 08:48 AM
Wait a minute. If you have two 5S packs, they must be connected in parallel, NOT in series since that would give you 10S! If you have a 2S pack and a 3S pack, then connect them in series for a total of 5S. Follow the advice in the owner's manual and time a 2 minute run with the new setup to make certain nothing overheats.
Indeed. I shouldn't assume he's using a 3s and 2s to get 5s. I figured 5s packs wouldn't fit. fluid explained it better than I.
belltec50
05-18-2012, 05:26 PM
I'm using a 2s and3s thks for all your help
Brushless55
05-19-2012, 10:50 PM
they will fit :tiphat:
belltec50
06-01-2012, 08:05 PM
I have't tried the 5s yet ,but i did go from a grim 42/55 prop to m455 on the mc and man it was worth it!!!! :thumbup:
D for Dummy
06-11-2012, 02:49 PM
I run two 2s, 4s total in mine. If I run 5s total what do I need to know about matching my existing 2s? does the c rating or mAh need to be the saem between the 2s and 3s?
martin
06-11-2012, 03:32 PM
The 42/55 prop is only 2.16" pitch the m445 is much higher pitch at 2.48" + being an m series the ears have been removed ( detonqued ).
