View Full Version : My scratch built Pontoon
in-d-boat
05-12-2012, 09:16 PM
This was something fun and different to build. Looks cool on the water. Just need some people drinkin' some beers on deck then it'll be complete!
galant2door
05-12-2012, 09:41 PM
I love the detail, looks great mate
in-d-boat
05-13-2012, 12:01 AM
Thank you, my friend!
Make-a-Wake
05-13-2012, 12:55 AM
Very nice...................got any more pics???
I blew up yours so i could see it better...................:Peace_Sign:
in-d-boat
05-13-2012, 09:17 PM
76379Yup, a few more.7637776378 And thank You!
Make-a-Wake
05-13-2012, 09:25 PM
Looks very scale!!! Great job.
hazegry
05-21-2012, 11:57 AM
how did you make the pontoons? I think this is one of the nicest pontoon boats I have seen.
mtbenjamin77
05-21-2012, 12:22 PM
Yes build pics please. whats the LOA? How much did it cost in materials?
in-d-boat
05-21-2012, 06:25 PM
Thanks, guys!
I made the pontoon logs from 2" phenolic rocket tubes. (actually 2.153 w/ 1/16" wall thickness) Then went over them with 3/4 oz. glass cloth. I left them hollow, no flotation, as anything added to the inside wouldn't do anything but add weight.
I chose 2" because it made everything easier to figure the scale out. 1"=1 foot. Most logs are 2'. LOA, from the prop to the points on the 'toons is 34". I'm guessing I have about $40.00 in it not including the EP-1 and the Tatic radio and the battery.
in-d-boat
05-21-2012, 06:33 PM
I made 1/8" lite ply plugs and glued the balsa blocks to them and rounded them off to make the backs of the pontoons. Then domed them a litlle.
in-d-boat
05-21-2012, 06:42 PM
For the front of the 'toon I used 1/8" lite ply for the keel and added 1" thick balsa blocks to each side. Shaped them on my disk sander and final sanded them by hand. Also made the 1/8" ply plugs, same as the rear. The stubby tubes they're mounted on are just to get the right O.D.7697176972769737697476975
in-d-boat
05-21-2012, 06:54 PM
Glued them together and went over everything with the glass cloth. I use 5 minute epoxy thinned 50% with acetone to attach the cloth. Let it dry overnight, sand lightly and apply another coat of thinned epoxy to make sure everything is well sealed. Then I spray sandable primer on it, wet sand inbetween coats, until it's smooth and the weave is filled.
in-d-boat
05-21-2012, 07:01 PM
Then it was onto making the mounts for the pontoons to attach the deck to. This took a bunch of time, but it's more scale than just glueing to the tops of the pontoon logs. (.030 styrene) plus some right angles.
in-d-boat
05-22-2012, 09:53 PM
Then it was on to making the deck.770647706577066
in-d-boat
05-22-2012, 09:59 PM
I made a third pontoon about half the lenght of the outer ones to mount the EP-1 too. Full size pontoons do this to help with the flotation for the heavier 4 stroke engines they're using. I used 1/4" aircraft ply for the motor mount with T nuts.7706777068770697707077071
in-d-boat
05-22-2012, 10:19 PM
Found a home for the servo and put the sheeting on the deck. I might add that I used the Bondex plastic cement rather than super glue. The Bondex melts the plastic together and forms, more or less, a solid joint. Where super glue will stick the pieces together ok, but doesn't bond them toether. Pieces will just snap apart. I never tried using the made for plastic super glue. Maybe that would work as well. The droplets are water from test floatin' it.7707777078770797708077081
srislash
05-22-2012, 10:20 PM
I kept skipping by this thread for some reason,but now I'm glad I stopped.That is really cool work there and it turned out fantabulous.I spent alot of time on these in the Okanagan here in B.C. This looks so cool,thanks for sharing.
Shawn
in-d-boat
05-22-2012, 10:28 PM
Then it was on to roughing in the sides. I made these with 1/8" square styrene and sheeted them with .030" Used a heat gun to soften the plastic and formed the radius around a 1/2" dowel. Too much heat and it screws up the plastic. Not enough, and it won't hold the shape. Alot of trial and error to get it right. You can "feel" when the plastic is the right temp. Hard to explain.7708277083770847708577086
in-d-boat
05-22-2012, 10:31 PM
Thanks a ton, Shawn. Happy that you like it!
in-d-boat
05-23-2012, 06:27 PM
Next came the helm and some "cushy" boat furniture. The cushions for the benches were made from using 5/16 x 1/4 1/2 bulb weather stripping. Works good and has an adhesive back. A lot of "that looks about right" here77138771397714077141
Make-a-Wake
05-23-2012, 06:39 PM
Very good work!!!:thumbup1:
in-d-boat
05-23-2012, 07:19 PM
I made a couple of "life jacket" storage boxes for the rear deck. One has the receiver in it, the other one has the ESC. It's a box over another box type of thing. All the wiring is routed above the center pontoon and never gets wet.77148771497715077151 And thanks again Make-a-Wake.
in-d-boat
05-23-2012, 07:26 PM
The battery compartment needed to be towards the bow and below deck. Also shows the rectangle channel for the battery wires to the center pontoon, through that to the ESC. A long lead doesn't seem to be a problem. It has room for 2 batteries but 1 runs forever. Not a speedy boat. Part throttle=looooong run times. 77152
in-d-boat
05-23-2012, 07:33 PM
Then I made a Bimini top for it. Used 1/8" round for the frame work. A couple of 1/8" square for the rear stationary supports. And 2 .010 thick "straps" for the front.7715377154
in-d-boat
05-25-2012, 09:01 PM
The whole boat was painted aluminum, 4 coats. I used Mono Kote trim sheets for the white and the designs. Sprayed Windex on the cut out sheet first, then "floated" them into place.77311773127731377314 The floor (carpet) is 2MM foam stuff I picked up at a Hobby Lobby craft store. And what pontoon boat would be complete without a grill? That's made out of a fishin' bobber and some leftovers. The tables are out of pizza boxes, I guess so the pizza doesn't stick to the lid. LOL.
That pretty much covers it. Thanks for all the positive comments, guys! 77315
In-D-boat
srislash
05-25-2012, 11:57 PM
Boy,that is great detail.And 1/12 scale? It would look good on the beach next to my scale truck
http://i1128.photobucket.com/albums/m488/SRIslash/Tuber002.jpg
Sorry bud I couldn't resist the pic and this is probably as scale as I possess for now.
P.S.: I love the grill and table.
in-d-boat
05-26-2012, 11:23 AM
Thank you! Cool truck! (Hummer?) Is that a winch on the front? Functional? Looks like I should get busy and make a trailer for the pontoon.
srislash
05-26-2012, 11:29 AM
Nope,it is just a toolbox.I needed it to fill in the huge hole between the lights and the bumper.I don't believe in winches for the 1:1 rigs either.There comes a point when hiking is quicker.Hehe
hazegry
05-27-2012, 10:12 PM
I hope you dont mind but I am so going to replicate this and build one for myself.
in-d-boat
05-27-2012, 11:52 PM
Heck, no. I don't mind in the least. I would consider it a compliment. I just wish I had some plans to pass along, but I don't. Sorry. Do you have an EP-1? Any outboard heavier would probably make her a little tail heavy. (or increase the lenght of the center pontoon and lower the center some for some extra flotation ) I have some 2 1/4" tubes that if I make another one I might see about the Stilleto outboard for that. But that would be down the road some. Thank you!
Karfrik
05-28-2012, 05:41 PM
Excellent job Keith!!!....you never sent me the pic with the grill on it!!!....you are the best!!
in-d-boat
05-28-2012, 07:49 PM
Ah thank you, thank you very much.
Jesse J
08-28-2012, 07:13 AM
I think I see the problem, you need some beer holders! whats worse than hanging out on the party barge and having your beer slip off into the drink?
great work, very innovative!
cheers
J
in-d-boat
08-28-2012, 10:13 PM
Thanks Jesse J! I'll have to get busy and make some holders. If I ever find the right people for the pontoon I'm gonna have the beers duct taped to their hands, so they don't spill any!!! Hahaha
Gusmoyer11
05-04-2014, 03:57 PM
Very cool! If you ever decide to sell it please let me know.
Gus
