View Full Version : Has anyone considered this?
SJFE
04-30-2007, 04:57 PM
Ok so it's only 110 amps...But man look @ the volts!!!!!!
CC Phoenix HV-110 Brushless Motor Control
Volts w/BEC No BEC
Volts NO BEC 50 MAX
Lipo Cells w/BEC No BEC
Lipo Cells NO BEC 12S MAX
NiCad or NiMh Cells w/BEC No BEC
NiCad or NiMh Cells NO BEC 36 MAX
BEC None (dual opto-coupled)
Continuous 110 amps
Minimum Cells 12 cells NiMH/NiCad or 4s LiPo
Switching Rate Programmable
(13, 26, or 52KHz)
Resistance 0.001 ohms
Brake Programmable
Reversible Yes - change any two wires
Low Voltage
Cut-off Programmable
Size 1.55 x 2.8 x 1.25"
Weight
(w/wires) 5.3 oz. (150g)
avengersteve
04-30-2007, 04:58 PM
did i read that right 50 Volts!!!
SJFE
04-30-2007, 04:59 PM
Yeah you did!! Man I can water cool that so easy. Same price as the hydra.
Eyekandyboats
04-30-2007, 05:04 PM
some people have run these in boats
larger boats like the Q,S and T i believe with good results. I was also informed you need a pistix as well.
I am hopeing to set up a T mono hull and thinking of this. or the tired and true 40,160
lferguson
04-30-2007, 05:05 PM
Yea, they have been used with get success in conjunction with Andys PiStix. Look at the "Falcon Reborn" thread on RRR. Sweet build and uses the HV.
SJFE
04-30-2007, 05:21 PM
I figured as much. Good to know. I think when I invest in a high end esc this one will be close to the top of my list:).
part time
04-30-2007, 05:33 PM
here is a even bigger esc jeti spin 200 Dimensions: 63 x 120 x 27 mm
Weight: 270 g
Nominal current : 200 A
Quiescent current:
1,4 mA
Accu NiXX / LiXX: 24-40 / 6-14
Operating voltage: 18-59V
Resistance in conducting state: 2x0,75 mΩ
Number of power transistors: 30
Cable cross - section (input / output: 2x4/4 mm2
Input capacitance: 2x820 μF
SJFE
04-30-2007, 05:45 PM
Is it under 300?
lferguson
04-30-2007, 07:02 PM
I think the Jeti spins are like buying Schulze in price and quality.. And I think UnitedHobbies carries them suprizingly enough. The 110HV's are very very nice.
SJFE
04-30-2007, 07:09 PM
Yes I have seen the jeti units @ United. It's a tuff call between the 240 amps on the hydra or the 50 volts on the HV.
