View Full Version : Eagletree 150 amp to 300 amps in 15 minutes
jcald2000
05-04-2012, 09:12 AM
You can, on the wire lead ET, loop 12 ga. wire from esc side directly to batt. side bypassing the board entirely for both the +7573575736 and - . This will bypass current, about 1/2, and let it run much cooler. You now have a 300 amp logger!
Those are 8mm connectors.
Next you need to access a Clamp on amp meter, clamp it around the battery leads and run the system up for 15 seconds or so logging the data and compare the amp readings between the them. The ET will have a reading of about 1/2 half of the clamp on meter.
Now connect your ET to the computer, go to "Advanced programming" click on "Calibrate volt and amps" and enter the actual readings in the appropriate boxes and save.
That all there is to it! Welcome to the 300 amp club!
Recorded 283 amp burst with 192 amp average.
Works great and is very easy to do.
Try it you will like it.
longballlumber
05-04-2012, 09:17 AM
Thanks for putting this up Jim! I will eventually make this change to mine so that I can get some decent data from my Q sport hydro...
Question – How does this change affect the logger when going back to P-Limited type set ups? Meaning is the fidelity of the readings equally good compared to an unmodified Eagle Tree Data Logger?
Thanks,
Mike Ball
oscarel
05-04-2012, 11:17 AM
Is the current offset a percentage? Just wondering how thats gonna work??
m4a1usr
05-04-2012, 01:49 PM
It could be if you wanted to scale the readings over the entire range measured. What ends up happening is the value you enter in after taking the half current reading will be offset to some degree, since wire, connectors IR and temperature are not compensated for over the operating range. But that amount is probably so insignificant who really honestly cares? I know, I know. Then whats the point of mentioning it? Just to put in perspective. This should be made in to a sticky for all to see if they want to mod their ET.
John
bigwaveohs
05-04-2012, 07:46 PM
So basically you added a shunt and then used a clamp-on ammeter to calibrate the readings?
jcald2000
05-05-2012, 07:32 AM
I used a load, light blubs at 40 amps, to calibrate. A higher load might be better, however I have had no problems. I haven't seen any difference from 4s to 8s. Remember we use these to compare different props, batteries, hull settings, ect. I don't care if it's 3 or 4 amps off.
carlcisneros
05-06-2012, 03:44 PM
Dumb question, what you happen if you added another wire in parallel with the
first wire installed on the ET?
Drax21
05-06-2012, 07:34 PM
Thanks for posting this. Can't believe I didn't think of it myself. That will give me something to do tomorrow:thumbup:
jcald2000
05-07-2012, 07:13 AM
Carl, the idea is to bypass 1/2 the amps form the ET.
Chrisg81983
05-12-2012, 01:16 PM
I did this quite some time back and it worked great on my systems that pulled high Amps but when tried with my lower amp setups I got data that was inaccurate sometimes and other times it was pretty close but for high amp setups it is a great modification and works well
jcald2000
05-13-2012, 07:28 AM
Humm, I use it on everything from P Limited to S hydro and haven't seen anything, except the usual have to keep the sensor plugs clean on the Logger. They can cause strange readings when they get loose or dirty.
Chrisg81983
05-13-2012, 11:12 AM
Jcald I tried everythng to get it rite but I no longer have the eagle tree as I just traded it to a good friend and most of my setups use castle hydra ice hv and lv controllers but I was wondering if you could shed some info on how you put the system under load for calibration efenpics will be great I am thinking about getting another one and my way of calibrating was a little different
jcald2000
05-14-2012, 07:34 AM
I calibrated by using 20 car tail light blubs soldered on brass rods, left over from our Nicad days over a decade ago, equaled 40 amps at 12 volts on a car battery.Loaded it for about 30 to 45 seconds to allow the bulbs to warm up and get stable reading.
How much load did you calibrate at?
Prop-a-Gator
06-01-2012, 03:10 PM
jcald, any chance you can make a quick sketch of your schematic? I think I understand what you are describing, but I like to be sure. Thanks.
oscarel
06-30-2012, 10:27 AM
So just verified with an EagleTree data recorder with 300 amp expansion and it's definitely very close!! I calibrated the elogger at 40amps while charging a lipo and once calibrated both recorders showed almost the same graph after a test run. Very nice find!
jcald2000
07-02-2012, 06:45 AM
How high can it go??
I just recorded a 372 amp peak for about 2 seconds when my 6s2p sport hydro submarined on launch.
Don't want to do that again!
oscarel
07-02-2012, 07:01 AM
I was only able to get around 190 before the mod then the solder would melt off normally on one of the negative terminals. So that puts it around 380??? Did that spike have a flat top?
jcald2000
07-05-2012, 08:03 AM
Yes!!
HydroMike
05-28-2014, 07:57 PM
Going to try this thanks
jcald2000
05-29-2014, 07:22 AM
A friend of mine bought a used ET on line that used a short 8 or 10 gauge as the shunt. Remember, the resistance must be the same for the additional wire, 12 gauge only and the same distance with a good solder joint.
Tamelesstgr
05-04-2016, 12:27 AM
Question, I don't have a high output charger, but I could in theory hook up my eagletree between my charger and the lipo pack I apply a charge to and then hook it up to the software in order to calibrate? My charger is capable of 5 amps max per channel.
05-04-2016, 07:34 AM
Two-year-old thread, and the OP hasn't logged on in five months......good luck.
dmitry100
05-04-2016, 07:44 PM
400 amp current sensor... https://www.sm-modellbau.de/UniLog-Stromsensor
05-05-2016, 09:39 AM
thats pretty nice.
Tamelesstgr
05-10-2016, 03:01 PM
Just waiting on parts, I am going to use a plane propeller to simulate about a 50 amp load on the motor with my shandard ETV4 150 amp logger to track. Then I should be able to take my modded ETV3 (Will be 200 amp version when I finish the modification above) and calibrate with the same load.
drwayne
05-22-2016, 10:31 PM
Have fwd that link to my daughter .. father's day is coming up :wink:
