View Full Version : Flex Cable
Big Lebowski
05-04-2012, 02:00 AM
Does anyone know the size of the stock flex drive cable on a MG? do i need to upgrade the flex drive since im going to put in a leo 4074 2200kv, seaking 180a, m445, running 4s2p 25-50c 6000mah? Any advice would be great. thanks
JimClark
05-04-2012, 02:16 AM
look on OSE store he has the upgraded cables
skyhighdiver
05-08-2012, 08:57 PM
.150 cable x 3/16 shaft
run what you have till problems arise then get this one or kinetic makes one as well.
Have hours of runs on my stock shaft with the same set up you have and no problems.
You will want to watch your bateries though that is your week link. Your set up has high amp draw and batterys will get hot quick maybe 3-4 min max
your Next set get 50 or 60c batterys and you will be set
Product ID: ose-geico-cable
OSE Upgraded ProBoat Miss Geico Cable
.150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is a higher quality with thicker
