View Full Version : Lipo Charger
Stuglas69
04-29-2012, 03:16 PM
This is a Electrifly Triton 2 EQ I have used it a couple of times but do not use it anymore. It is in excellent condition, it includes the instructions, stickers, deans plug, both balancing boards, alligator clips and the AC supply.
150$ shipped.
http://s818.photobucket.com/albums/zz103/summit25/?action=view¤t=DSC_2176.jpg
Chrisg81983
04-29-2012, 07:00 PM
Specs on it will help I am interested thanks chris g
JimClark
04-29-2012, 07:08 PM
Specs
AC input voltage: 110V 60Hz — 240V 50Hz DC input: 11-15.0V, banana plugs with mating gator clips Number of outputs: one Battery types, # cells: 1-24 NiCd, NiMH (1.2-28.0V); 1-6 LiPo, LiIon, LiFe (3.3, 3.6 or 3.7V cells); 6, 12, 24V Pb (2V per cell) Fast charge current: 0.1-8.0A linear NiCd, NiMH, auto mode 0.1-8.0A for lithiums (120W max DC, 100W max AC) and Pb Fast charge termination: peak detection for NiCd, NiMH Cc/cv for Pb and lithiums Optional thermal cutoff for all battery types Fast charge safety timer: 0-990 minutes Discharge current: 0.1-3.0A Discharge cutoff voltage: 0.5-1.2V per cell NiCd/NiMH; 2.8V per cell LiPo/LiIon; 2.5V per cell LiFe; 1.8V per cell Pb Battery memories: 10 Programming controls: Dial, 2 push-buttons Display type: 2x16 reverse LCD w/backlight and adjustable angle Audible indicators: 10 melodies, on/off Case material: extruded aluminum Thermal cutoff: 50-150°F (10-65°C) Safety devices: solid-state overload Cooling fan: built-in Case size: 7.2 x 7.0 x 2.44 in (184 x 178 x 62 mm) Weight: 54.5 oz (1546 g)
NiCd/NiMH specs —
Trickle current: 0-300mA Peak sensitivity: 5-20mV NiCd/3-15mV NiMH Peak delay at start: 0-60 minutes Cycle count: 1-10 cycles Cycle delay: 1-60 minutes NiMH maximum charge cap: 0-9900mAh NiMH top off charge: 0-1000mA
Lithium specs —
Balancing accuracy: 5mV per cell Balancing connector: JST EH type-adapters available separately Maximum node current: 300mA
Stuglas69
04-29-2012, 07:23 PM
Specs
NiCd/NiMH specs —
Lithium specs —
Thanks for specs!!
Chrisg81983
04-29-2012, 08:54 PM
Thanks much guys but I am looking for something with higher amp output for lakeside use my hitec dual charger puts out ten to each pack good luck with sale Chris g
Stuglas69
04-30-2012, 02:50 PM
145$ shipped!
Stuglas69
05-02-2012, 03:20 PM
140$ shipped!
Stuglas69
05-04-2012, 09:45 PM
$130 shipped!
Stuglas69
05-06-2012, 01:53 PM
125$ shipped!
Stuglas69
05-06-2012, 05:11 PM
sold
