View Full Version : Apache transformation?
takeaim17
04-28-2012, 08:43 PM
Hi guys,
I have an Apache 24 that I would like to turn into a decent FE boat. I already have a leopard 3650, 2930kv brushless motor with a 120 amp esc, planning on running 2s, possibly 3s lipo. What are the next steps to transforming my apache?
Thanks,
Ben
Diesel6401
04-28-2012, 09:07 PM
Hi guys,
Thanks,
Ben
The apache isn't the overall best boat for brushless power, but it can work. The hull wasn't designed to handle the speeds of brushless power. I do however believe their are a few threads on moding them and overcoming any potential problems. I don't trust brushless + plastic, so reinforcing the hull with some f/g or c/f would help a lot. I also believe the stock steerable outdrive may become an issue. I actually slowed my apache down further then it comes stock. I would guess I'm getting about 7mph at most if that, but its the most reliable and important boat in the fleet and turns the most heads.... I converted it to a rescue boat!
Sent from my T-Mobile G2 using Tapatalk 2
roadrashracing
04-29-2012, 09:41 AM
Hi guys,
Thanks,
Ben
If you have the stuff already put it in keep it easy, and maybe upgrade the prop, when you want more upgrade to a fiberglass boat, I would just not stick a lot of time or money in that hull.
takeaim17
04-29-2012, 10:29 PM
I already have one homebuilt FE wooden hydro that runs great but I really want to turn this apache into something worthwhile.
I just gutted it so everything is open as others have done. I think the next step is to get some fiberglass and reinforce the hull. After that, I was thinking about getting either a flexshaft or wire drive system and locking the outdrive in a straight position. Then use a side rudder as others do. What side rudder should I get? Any other ideas/advice?
Thanks
