View Full Version : Trim Tabs on a cat?
connorryder
04-25-2012, 01:48 AM
Hey i was just wondering if you can out trim tabs on a cat (pro boat mystic).
Will doing this help the handling of the boat? Or not really help at all?
Any help would be great!
Thanks
Garrett
09-15-2012, 01:15 PM
it probably would help, tho you could try adjusting the propeller strut. I found that if you adjust the strut down, it makes the boat porpoise more; but if you adjust it up, as awkward as it sounds it does in fact make the boat ride flat.
I've installed a secondary rudder, using it as a trim tab, and a 2nd water pickup. she dances on the water. its really cool.
Make-a-Wake
09-15-2012, 01:30 PM
Trim tabs on a cat is trying to help a bad setup. Adjust COG, strut etc first.
09-15-2012, 02:52 PM
Four-month-old thread, I'd assume that he's well past the issue.
mannytx1
02-05-2014, 04:15 PM
111452
Spartanator
09-29-2014, 12:07 AM
Bringing the thread back...
So I assume that tabs only help during the planing time but also a little "bounciness"?
I have a 32" Rivercat but I run in the choppy waters so I can't really get on it or it gets in the air...
Would a led weight help up front?
