View Full Version : Prop m445
esoteric107
04-24-2012, 10:52 AM
I just ordered the m445 prop for my new boat I am building. I need some info on a easy to use balancer thats recommended.
G-UNIT
04-24-2012, 11:30 AM
I use a truflight from my lhs works great for me, aout 20.00
Pretty much all balancers will do a fine job if you use it rite.
785boats
04-28-2012, 04:40 AM
Esoteric.
Right here on OSE is a good place. Here's a link to it in Steve's shop.
http://www.offshoreelectrics.com/proddetail.php?prod=ose-80310&cat=123
TheShaughnessy
04-28-2012, 04:03 PM
i like the topflight one cause it is a only 20 bucks, but there is a magnetic one that comes with different size shafts, 1/8th, 3/16th, 1/4 for use with different prop hub bores and is what i would get , if i didn't already have the topflight one. The topflight uses a single shaft with tapered "slide nuts" i'll call them which have a tendency to wear.
I would really like to get a 3/16 shaft for the topflight, but never had success trying to make my own and i couldn't tell ya how to get one.
CHIEFY_44
04-28-2012, 08:01 PM
Hyperformance make a gd mag one with the different rods for the shaft sizes also here on ode store they have something similar.
jcald2000
04-29-2012, 06:40 AM
I have used the Topflight for over 10 years, all you need to do is get the "hand prop balancer" from Tower Hobby. It has two tapered alum. nuts on a pointed treaded shaft. Fits 3/16 and 1/4 no problem.
