View Full Version : what motor
HondaHead
04-15-2012, 08:27 PM
been running 5s5000mah with a spartan prop with stock motor and esc plenty of fun but just got a seaking 180 amp and going to 6s5000mah35c(2 3s) what would be a good motor for this setup just for general bashing and maybe some all out runs
Rumdog
04-15-2012, 08:28 PM
in what boat?
Make-a-Wake
04-15-2012, 08:29 PM
What boat???? You state that you are running a "Spartan prop" and some "stock motor"....................is it a Spartan?
HondaHead
04-15-2012, 08:30 PM
sorry bout that its a proboat mystic
Make-a-Wake
04-15-2012, 08:38 PM
It would rock with this motor on 6s
http://www.hobbyking.com/hobbyking/store/__17710__XK4060_1500KV_Brushless_Inrunner.html
HondaHead
04-15-2012, 08:49 PM
thanks,i just got the mystic 2 weeks ago and I'm new to the brushless set-ups and boats in general,trying to learn a lot to quickly
HondaHead
04-15-2012, 09:02 PM
any recs for somthing a little faster also just want to cover all my bases
Make-a-Wake
04-15-2012, 09:27 PM
This one may work.................:banana:
Make-a-Wake
04-15-2012, 09:31 PM
But seriously, this Leopard 1400kv on 6s would be almost uncontrollable: http://www.offshoreelectrics.com/proddetail.php?prod=leo-4074&cat=148
I'd go with a 3674 if it were mine, the 1400kv and you could swing a 6 pitch prop with some decent diameter............plus it would probably go right into the stock mount being a 36mm http://www.offshoreelectrics.com/proddetail.php?prod=leo-3674&cat=148
HondaHead
04-15-2012, 09:44 PM
thanks again, prob going to go with the 3674 sounds like a compromise between fast and FAST
HondaHead
04-15-2012, 09:46 PM
BTW what would that huge motor go in if its even real:beerchug:
Make-a-Wake
04-15-2012, 09:55 PM
They are real, and they are used in Big-A$$ airplanes mainly, here's a whole page of big outrunners http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=522
HondaHead
04-15-2012, 10:37 PM
That's sick over 2 pounds of just motor alone,I've got lots of reading to do,thanks again
HondaHead
04-16-2012, 07:14 PM
Any thoughts on a ul-1motor was recommended by one of the guy
At the local lake
TheShaughnessy
04-17-2012, 10:12 AM
its a good motor but unless you are spec racing go with the leopard. I have a 4074 2000 kv on 4s and am not sure why anyone would want to make the boat faster then that, pretty damn fast for a 29 inch boat.
Ul1 motors are great, but not for 5 and 6s. To run that number of cells you need to be between 1500 and 1800kv
HondaHead
04-17-2012, 04:47 PM
Thanks a lot,just trying to get a good solid set-up,boat handles good and plenty fAst on 5 cell
With spartan prop,now it needs to go faster
keep in mind, jumping up 1s in your packs is a big difference on the motor. a motor that might be perfect for 5s will be too much for 6s.and it works the other way. if i were planning on running two seperate cell counts in the same boat, in your case (5 and 6s) you would be better off getting a motor that will handle 6s well. sure, 5 s wont be a rocket, but you can switch props around to gain more speed. better than having a rocket on 5s and blowing up your motor on 6s… get it?
HondaHead
04-17-2012, 09:26 PM
I learned that from reading on here but thanks agian
So once I get a motor(already have a 180amp esc ) I'm just gonna
Run 2 3cells and be done
