View Full Version : How should I fix this Flex Shaft?
Visual Perfection
04-10-2012, 07:21 PM
Had my Fastech out last time and it quit out on the water, motor revved but no movement.
After getting it in I found the flex shaft was the culprit
Here is what is should look like all one solid piece
http://img.photobucket.com/albums/v716/z28toaz34/IMAG0885.jpg
here is how it is, the end piece just turns freely and can be pulled off as shown in the picture.
http://img.photobucket.com/albums/v716/z28toaz34/IMAG0886.jpg
How do I re-attach it, or do I need to get a replacement?
Thanks
dana
04-10-2012, 08:23 PM
if it was soldered in you can heat with torch and resolder.
Visual Perfection
04-10-2012, 09:12 PM
Well I don't have a torch, but will have a new soldering iron (100w) arriving in the next couple days so I will see if I can do something with that.
dont slow down
04-14-2012, 06:43 PM
This just happened to me about 30 min ago. So it's just soldered?
Visual Perfection
04-17-2012, 03:03 PM
Ya I fixed mine by just re-soldering it on..unfortunately when putting it back in the motor was a little mis aligned and I forced it too hard and wrecked the other end..go figure
So a new drive shaft I will need..just can't get one now as I am not spending any more money on my boats since we just found out we have a baby on the way so priorities have changed... So my fastech is now dry docked for a while lol
SirBudman32
04-17-2012, 03:16 PM
Is that a 4mm flex with the square drive on the end? and if so how long is it I may have one.
G-UNIT
04-17-2012, 03:19 PM
I use green loctite, bearing retainer, and it works great on the stub shaft, never lost a prop yet,
Visual Perfection
04-17-2012, 04:37 PM
I'm not sure what size it is, it's the stock shaft for a proboat formula fastech. Maybe someone can chime in that knows.
SirBudman32
04-17-2012, 04:43 PM
I have a piece that is 9 3/4 inchs long that I dont need. If it will work, could send to you.
