I am not looking for any lectures about inexpensive radios but has anyone used this radio in a boat? I am a two stick kind of guy and the receiver antennae is very short. Will this setup have any range issues with a good electric hull or perhaps the Genesis Cat?
Turnigy 9X 2.4 radio receiver antennae
You will actually have better range with no interference issues with that "short" 2.4 Gig RX antenna, unlike the FM crystal TX and the crystal RX with a "long" antenna. I have a pile of what were top of the line FM pistol grip and airplane radios - now worthless & collecting dust. They turned all of my 3D airplanes into piles of sticks due to FM interferenceJIM
JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract SpecialistComment
Jim, the short antennae for the Turnigy receiver in question is only 4.5 inches long total. The marine or surface versions of Turnigy radios are longer. There is no way to extend the antennae lead out over the deck so I am concerned. Jim I believe we have met before perhaps at the SGRA Hydro Invitaional years back or the Indy Unlimited. I have been around a long time but am new the electrics and 2.4 ghz.Comment
Is the antennae attached by a small gold plug or is it soldered on? If it's a plug you can use an aftermarket longer 2.4 antennae as only the very end of the antennae is the "tuned" part, only about a couple inches is actual antennae, the rest is coax feeder to extend that little end part.If my boats upside down then who owns the one I thought I was driving the last two laps?Comment
The antennae is soldered to the receiver board. I have ordered a marine receiver for this radio that has a 26 cm (about 10 inches) antennae lead. I would feel more comfortable with that. There is another boat forum that has been a buzz with this subject and many of the guys say they just lay the antennae flat to the bottom of the radio box and have no problems. Then there are a few that have various equipment for sale saying they could never trust the range of a air receiver used in a surface or boat application. Futaba offers for a price a 15 inch marine antennae option for their receivers.Comment
Dave, that wasn't me at Indy. But it may have been one of my relatives as the family core is in Kansas/Missouri. If 1945 is the year you were born - we do have that in common, as well as a love of RC anything. Hope you didn't take my reply to your thread wrong, I was trying to help, not talk down to you. JIM
PS: If you mount the RX with velcro near the top of the sponson you would have all but about 1/4" of your antenna sticking out. None of my boats have more than 4" showing & I have yet to have any reception issues even at 1/2 mile away.Last edited by JIM MARCUM; 04-10-2012, 02:45 PM.JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract SpecialistComment
Hey Dave, it's been a while. I've been out of boats for a while, but came across this thread Googling for something else. This thread is old, but both you and Jim have been helpful guys so I thought I'd ask if you found the answer you were after.Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.Comment
ything
Like Jim, I have a ton of now obsolete expensive Futaba PCM FM radios and receivers that are basically paper weights. One of my racing buddies talked me into trading some of my PCM receivers for his obsolete junk but each receiver originally cost more than the complete 2.4 Turnigy setup. Since then however I see these radios being used by many guys on some pretty expensive models. Our local Hobby shop even stocks these Turnigy radios in both the 9 channel aircraft version and the pistol grip surface version. While he doubles the price on the items I get a certain satisfaction knowing I am not alone in going cheap.
By the way, early on I had to prove to my self everything was trust worthy so I experimented with the failsafe programming and gained enough confidence that I trust these systems even more than any of my respected PCM systems.
Perhaps another footnote: I added the Quanum telemetry monitoring system to some of my better models. To have feed back live as to onboard items like battery voltage and temps. This device has a even shorter antennae and gave no thought to trying to get the antennae above the deck line of the boat and I have yet to lose communication with that system either which is also on 2.4 ghz.
Color me very happy with 2.4 and short antennaes.
DaveComment
Dave,
Good to hear you proved it for yourself and are satisfied. I was going to chime in to say that you should have no problems passing 2.4Ghz through the fg Genesis hull. The reasons one may still want to stick the tip of the antenna out of the hull would be to avoid radio obstructions from internal components (motor, lipos, etc) as the boat's relative orientation changes and to optimally orient the radiation pattern. These 2.4GHz dipole antennas have a null point along their axis. If you lay the rx antenna horizontally, you will eventually have the null pointing at your tx as you maneuver. This may not matter or be noticeable if your are keeping your boat relatively close as most people do, but if you are pushing your range it can result in glitches or loss of signal.
BTW: only final the ~31mm of your 9x rx antenna is active. The rest is shielded length to help with placement.Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.Comment
