View Full Version : Power supply suggestions
RIPFENCE
04-04-2012, 08:14 PM
I am going to invest in a new hyperion charger that will need a 24 volt power supply to take advantage of its full capability..i have done some quick research but i would rather listen to others here on the forum who have had good results...i am either buying the hyperion 1420inet3 or the 730inet3...i think the spec should be around 50 amp capable
anyone using something like this for their hyperion chargers?
Thanks
rip
JIM MARCUM
04-04-2012, 08:49 PM
You might want to look at this: http://www.ebay.com/itm/LED-POWER-SUPPLY-100-WATT-100W-24V-24-VOLT-SDMV24100P-/390277823002?pt=Laptop_Adapters_Chargers&hash=item5ade5efa1a JIM
Snowride
04-04-2012, 09:24 PM
Here is a nice unit how ever it does a max of 18v but can deliver 540 watts (30Amp) . http://epbuddy.com/index.php?main_page=product_info&cPath=5&products_id=207 I use the smaller 300 watt (20Amp) unit which is adjustable from 6 to 12 and performs flawlessly. http://epbuddy.com/index.php?main_page=product_info&cPath=5&products_id=207
RIPFENCE
04-04-2012, 09:40 PM
here is a nice unit how ever it does a max of 18v but can deliver 540 watts (30amp) . http://epbuddy.com/index.php?main_page=product_info&cpath=5&products_id=207 i use the smaller 300 watt (20amp) unit which is adjustable from 6 to 12 and performs flawlessly. http://epbuddy.com/index.php?main_page=product_info&cpath=5&products_id=207
looks like a good deal for the specs
i belive in order for me to get the 550 watts out of the hyperion i need 24-30 volts..18 is not bad at all though for that cheap of a price
max amps sells one that will do the job but its 150.00..maybe i can find out which one is just rebadged in the max amps packaging and cut out the middle man so to speak..
Thnks guys
turbonutt
04-04-2012, 09:46 PM
What about 2 of the 47 amp server power supplies wired together? They are super easy to mod and you can pick them up for pretty cheap
m4a1usr
04-04-2012, 10:26 PM
Rip,
Get two of the many available server PS and wire them together. You need 50 amps at 24 volts? Thats easy. For about $60-70 and an evening of adapting you can have all the power you need. But they can be a bit noisy if you havent built these server PS out there. I'm happy with mine. Just be aware they are noisy. Lots of air being sucked in. Also for a full 50 amps on 24 volts off 110vac wall power make sure you have a dedicated 30 amp outlet. The normal 15 or 20 shouldnt be trusted.
John
oscarel
04-04-2012, 10:38 PM
Here's all the info you'd ever need on converting them.
http://www.rcgroups.com/forums/showthread.php?t=1292514
http://www.rcgroups.com/forums/showthread.php?t=1005309&highlight=348114+b21
lenny
04-04-2012, 10:56 PM
Hears a link,http://forums.offshoreelectrics.com/showthread.php?24308-GREAT-deal-on-power-supplies!
This is the one I have, Sounds like a hair dryer on low speed.
But works good.http://www.ebay.com/itm/170615236018?_trksid=p5197.c0.m619
Snowride
04-05-2012, 05:19 AM
IMHO I think the puter power supplies look like some poor boys after thought even though they work. Would much prefer to have a dedicated unit like the ones I posted for not that much more by the time you are done soldering and tinkering plus the fact they are small, quiet and super cool looking.
http://i44.tinypic.com/33nunti.jpg
HydroMike
04-05-2012, 05:24 PM
These r vary nice two 12 volt PS to do 47 amp love mine http://forums.offshoreelectrics.com/showthread.php?32605-12v-and-24v-power-supplies&p=397576&highlight=#post397576
Or you can check.
http://www.ebay.com/itm/DC-Power-Reyed-480w-24V-20A-Switching-Power-Supply-/180751231592?pt=FR_YO_MaisonJardin_Bricolage_Insta llationElectrique&hash=item2a159cea68#ht_3171wt_887
RIPFENCE
04-08-2012, 07:44 PM
thanks guys for all the good info now i have a lot to think about
Cooper
04-22-2012, 07:59 PM
Thanks
rip
Unit Prices:
1~9 pieces $74.47 each
Higher Qty's: Request Quote
Output Specifications:
Output Voltage: 24 Volts DC
Min Current: 0 Amps
Max Current: 18.8 Amps
Power: 451.2 Watts
Input Specifications:
Input Voltage: $75.00 at trcelectronics.com. More amps if u want to spend more
