View Full Version : P1 35" KOS Modding and testing info,With links.
lenny
04-02-2012, 09:29 PM
Hi,:tiphat:
Just trying to have the info in one place to look,
To make it easier to find when you need it.:beerchug:
Hears the link for the info,http://forums.offshoreelectrics.com/showthread.php?32137-P1-kos-35-quot-offset-rudder.
Joe007
04-07-2012, 02:15 PM
Thanks Lenny I am a slow learner, but a happy learner. I hope to have some info on my boat in the near future. Waiting on the stock in out drive to show up it is on back order.
lenny
04-07-2012, 03:47 PM
Joe, Do you have any pictures of your boat hull ?
Also hears a link for the stock stinger at TowerHobbies and it in stock,http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBRMM&P=Z
And why do you want the stock hardware for your boat ?
Instead of something better and probably cheaper in the long run.
Joe007
04-07-2012, 05:11 PM
Lenny I the stock rudder arm kit. So I thought I would have to by the stock outdrive because they mount in tandem. The speedmaster 3/16 stinger looked like I would not be able to mount the rudder arm above. So do you think I should buy the speedmaster stinger and then off set the stock ruddder?
lenny
04-07-2012, 05:55 PM
Joe, Do you have any pictures of your boat hull ??:popcorn2:
I am not sure about what you want to do,
Do you want a inline rudder or offset rudder ?
How much $ is the stinger you have on back order ?
With the curved p1 transit, You would need to makes a spacer of some kind.
Was your hull already drilled for the stock hardware when you got it ?
Joe007
04-07-2012, 06:28 PM
73962]Lenny I think I would rather go off set rudder.it is pre drilled. The stock outdrive (stinger) is $34.
lenny
04-07-2012, 06:51 PM
Ok, Whats in side the hull ?
Where did you order the stock stinger ?
I would buy the one from tower, And cancel the one on back order.
You will need a trim tabs & turn fins, yes ?
And what about servo and motor mount and motor & coupler and a flex shaft, prop dog, prop ?
Joe007
04-07-2012, 08:57 PM
The hull only has the stuffing tube. I have a wate cooled motor mount from ose. I bought a turnigy 500 1600k outrunner,a aquastar 90a esc. I bought a set of turn fins off of ebay, have not ordeed the trim tabs yet. I have a traxxas 2056 waterproof sevo. And instead of a flex cable I was going Jeff and order his piano wire shafts. I am going to start with a 640 prop.
lenny
04-07-2012, 09:17 PM
That stuff should all work nice,
I am using a x440/3 prop, I had a x642 on it and got the same speeds as the x440/3.
But more run time with the x440/3
Will you be running 3s or 4s and 1p or 2p ?
I would fill the stock trim tab holes and get something better then them.
Joe007
04-07-2012, 09:29 PM
7397473974Lenny I was thinkin of these trim tabs they are 42mm X 29mm.
lenny
04-07-2012, 09:48 PM
The stock ones I have that I modded are just about the same size, Give or take 1mm.
How thick are they ? Mine are 9.5mm.
I think they will work fine, But do they just have one mounting bolt ?
Joe007
04-08-2012, 08:44 PM
The one's I am getting have two mounting screws and the thickness is 10.5mm.
lenny
04-08-2012, 08:58 PM
Ok, In the pictures it looks like one.
I will make a pattern of my offset bracket,
I should have did that before I tested it.
Will you be running 4s or 3s ?
Joe007
04-08-2012, 11:38 PM
Lenny I will be running both 3 and 4s lipo 2p.
Joe007
04-18-2012, 04:20 PM
Lenny how far from the center of the outdrive did you put the rudder? I got the stock stinger today. Are you running the stock flex shaft? I am thinking of going with the piano wire set up from Jeff. What do you think?
lenny
04-18-2012, 06:54 PM
Hey Joe,
Rudder is 1 1/2" offset.
It is in post #31 in mods, And no.
My flex is a 187.
Piano should be good, You just need to find a way to seal it.
At the stuffing tube inside the hull to stop water from coming in.
detox
04-18-2012, 07:10 PM
A small piece of silicone fuel line will work to seal it.
lenny
04-18-2012, 07:52 PM
Thanks for the info,:tiphat:
I was not sure about the piano wire and doing that to seal it.
I have never used one yet.
Joe007
05-22-2012, 05:42 PM
Lenny I got the speedmaster stinger strut today. Wow what a difference from the stock out drive. Will be getting it together in the next week o two. Thanks for the help.
lenny
05-22-2012, 07:45 PM
Pm sent.
