View Full Version : Impulse 26 with MIss Geico Guts VIDEO
POWERS
04-02-2012, 12:12 PM
Got my dad an Impulse 26 for this past christmas. I had the stock electronics from my miss geico lying around so I did a little transplant surgery. All in all the swap over was ridiculously easy and it makes me want an Impulse 26 now, although I may just jump up to the 31. As stated set up is stock Probaot 60amp esc and 1500kv motor out of an MIss Geico. Was running a 3300 mah 4s in the video and the stock plastic prop. Gonna throw a x645 on her and either a higher kv motor and stick with 4s or a larger esc and go for 5-6s just for the hell of it.
http://youtu.be/G8qnMwAuX7M
hazegry
05-12-2012, 09:32 PM
boat runs good I just put a UL-1 power plant in mine and ran a 642 prop I got pretty much the same results I think you will really wake it up with a metal prop. This little boat takes power upgrades pretty good and they are easy to swap out I did it in the time it took my 2 batt packs to charge.
Make-a-Wake
05-12-2012, 10:21 PM
Love it!! :buttrock: I get great pleasure crammin big motors in small hulls myself. I think you'll be disappointed with an x645 as it is SO much more prop than the stock one. Torque roll will be horrendous, and torque steer will keep it on a right turn path almost constantly. Conisider making it even faster(its already bad-a$$ for an Impulse 26), but keeping it controllable with an m445 or s220 possibly.:Peace_Sign:
Make-a-Wake
05-12-2012, 10:24 PM
I think the stock prop is fairly beefy.......................its like an s215 isnt it?
Tamelesstgr
07-28-2015, 06:06 AM
Was just curious if you were using a single 4s pack with the 1500kv motor?
gearhd48
07-28-2015, 08:32 AM
With the 60 amp ESc as he said he had he can only run 14.8v or up. LVC is set for higher volt batteries. The 35-50 amp ESC's can only run up to 12.6
