View Full Version : Is this too much prop for my boat
galant2door
03-23-2012, 06:44 AM
Hi guy's, I have an octura x645 from my brushed rc boat days and I am curious to know will it let the magic smoke out of my speedy if I give it a whirl. I have a 32" cat running on 4s, swordfish 200a speedy and a leopard 3665 2100 kv motor. Hope thats all the info you need. Any advice will be taken onboard as all the info i have got off this site and the people who seem to live on here(like me) have saved me money and nothing has burnt out yet. Thanks guys, Gus from Oz: thumbup:
Chrisg81983
03-23-2012, 07:16 AM
What prop are you running rite now and what are your temps and how many amps are you pulling rite now with current prop
Diesel6401
03-23-2012, 07:40 AM
x645 is too much prop for that motor IMHO. A x440, x442, grim 42x55, prather 215, x642 would be better suited. You may even be able to try a m445 or a prather 220. I would start small and work my way up. That x645 though will end up letting the smoke out of something.
Chrisg81983
03-23-2012, 08:17 AM
That's what I was getting at I have a similar setup in a 30 inch cat that I built for my nephew and the grim 42/55 and an m445 are about it try the props that diesel recommended they should be within the safe sone just watch temps closely I ran the 645 a few times it will work with my setup but cuts it a little close especially now that we are going into the summer months
jamespl
03-23-2012, 08:25 AM
I run the x645 in a genesis on 4s with a 4074 2000kv motor and t180 esc. I didn't realise it was quite an aggressive prop. My temps seem fine though.
Diegoboy
03-23-2012, 08:47 AM
Moved
galant2door
03-23-2012, 05:14 PM
Sorry diego, my bad. Thanks for the input guy's. I am running a 40mm 3 blade prop at the moment, i am not sure on the exact specs as I cant see the print on it like the octura prop. Temp's are nice and cool, I can touch everything and only warm, not sure on amp draw though. I will buy some of the props suggested by diesel and go from there. Start small and work up. Cheers Gus
Diesel6401
03-23-2012, 06:46 PM
Your motor has less kv (more torque) and larger sized rotor (more torque and wattage) vs. his 3665 motor so your motor can spin the larger prop easier. I ran a m645 which is less amp draw then the x645 with a 4074 2200kv leopard and the motor pulls some amp and can heat up if im not careful. It's a lot of prop and you have to be careful with it especially with higher kv motors.
tlandauer
03-23-2012, 07:09 PM
Sorry guys, don't mean to hyjack the thread. I was going to put a m445 on my Pursuit ( Leo 2200Kv, Seaking 180A and 4s setup). But now I just realized the prop I had is a m545, is m545 alot more prop than m445, don't see this prop mentioned here often, any help is appreciated.
Diesel6401
03-23-2012, 09:51 PM
The m445 is 1.4 pitch the m545 is 1.5 pitch so yes its more prop then m445, but isn't as much as a jump as the m645. My Leo 2200kv, spun the m645 but I had to be very VERY careful with it. The leo 2200spins the m445 very well so the m545 maybe a nice happy medium. Set the timing to 11.25 and give it a try. Run for only a few mins and check temps on everything including the bullet connectors. If you have a datalogger that would be awesome. Note that I only run 2p setups with Leo 2200
Sent from my T-Mobile G2 using Tapatalk
tlandauer
03-24-2012, 02:53 AM
Thanks for your input, I will be careful and hope this "happy medium " works out.
Just to clarify, you say you only run 2p setups, do you mean you only run 2s set-up which is only 7.4v. I am still new, don't know some of the terms.
Chrisg81983
03-24-2012, 04:10 AM
Thanks for your input, I will be careful and hope this "happy medium " works out.Just to clarify, you say you only run 2p setups, do you mean you only run 2s set-up which is only 7.4v. I am still new, don't know some of the terms.A 2p setup for example is running 2 4s packs parallel instead of running 2 2s packs in series it definitely helps when trying to run larger props
tlandauer
03-24-2012, 12:51 PM
Thanks, I did wonder if that was what Diesel meant. Thanks guys!
