View Full Version : Bought a Ekos P1 hull
Joe007
03-22-2012, 12:13 PM
I need some help, I bought a new ekos P1 vee hull. I need some measurements of some of the stock hardware. The stinger length and the length of the rudder and rudder bracket. And help would be appreciated.
Joe
Alfa Spirit
03-22-2012, 02:08 PM
The stinger lenght is 1/10 of hull lenght, Speedmaster stinger strut is ok, for 3/16 propeller shafts http://www.offshoreelectrics.com/proddetail.php?prod=ros-stinger-str
This Speedmaster rudder is perfect http://www.offshoreelectrics.com/proddetail.php?prod=ose-80050
Use a 3/16" flexcable http://www.offshoreelectrics.com/proddetail.php?prod=ose-1190
What kind of setup for this hull? 4S or 6S? I think the Venom KOS P1 must be reinforced with carbon layer
Joe007
03-22-2012, 02:11 PM
Thanks for the info
lenny
03-22-2012, 03:34 PM
Hi,:tiphat:
Welcome to the club,
I have bin adding info to this thread so it will be easy to find later on in one place.:beerchug:
Hears some info and ideas on this boat.http://forums.offshoreelectrics.com/showthread.php?32137-P1-kos-35-quot-offset-rudder.
Joe007
03-22-2012, 03:59 PM
Thanks Jenny but first I have to find out what the stock distance from the transom to the leading edge of the rudder is?
Alfa Spirit
03-22-2012, 04:17 PM
Why? If you choose the correct hardware for a 35", forget this stock hardware
Joe007
03-22-2012, 04:26 PM
alfa I am in the dark on this rudder and stinger setup? Should I go with a longer or shorter rudder bracket? For a motor I am thinking of the turnigy outrunner 1600k. I also want to go with the panio wire drive, what do you think?
Alfa Spirit
03-22-2012, 04:33 PM
Piano wire is for small boats, I give you the answer : 3/16" flex and drive shaft. I don't know this Turnigy motor, consider Leopard motors, 4082 1450kV is a very good choice
lenny
03-22-2012, 05:23 PM
Ok, Stock stinger 2"3/4 off transit, And rudder leading edge to transit is 4"1/8.
Did you look and read the link info on motors and mounts ?
I am running .187 flex with modded stock stinger and stock 2000kv outrunner on 4s.
lenny
03-22-2012, 05:31 PM
The boat hull is 31"1/2 long and 7"wide,
It can not handle to much motor or prop with out torque rolling all the time.
Joe007
03-23-2012, 05:20 PM
Lenny thank you for the stock measurements.
Joe
Joe007
04-20-2012, 05:22 PM
Just applied another laye of fibeglass to the inside hull. Gotta let it cure fo the next couple of days. I have to add just a little more fg to the inside nose. I am going to use a thicker piece of fg to put up in the front hull to add some weight to the nose.
Alfa Spirit
06-29-2012, 09:33 AM
I put an order for a P1 KOS hull undrilled and its canopy, 150 €uros shipping to France included. I want to use a set of outrunner motors 500 class 1700kV. One 6S battery, two Seaking 120A and two FMT 3650 1700kV motors
