View Full Version : Pre Balanced Props
dag-nabit
03-13-2012, 03:11 PM
Kintec Racing is now offering a line of pre-balanced CNC machined aluminum props.
I haven't tried them, but the should be lightweight, and they are machined instead of cast.
Could be interesting
Kevin
Bullwink
03-13-2012, 03:19 PM
I have used one before, X444 and I ordered some more yesterday. It worked fine with no noticeable bending. I ran it on a Pro Boat Impulse31 with a UL1 motor. It ran 36.8mph. I ran the same setup this past weekend with an Ocutra X445 and it ran 38.6. So I think that is about right as far as an increase in speed.
martin
03-13-2012, 03:58 PM
The downside to the aluminium props is their more delicate & damage quite easy.
JimClark
03-13-2012, 04:05 PM
I would assume they are heat treated
martin
03-13-2012, 05:29 PM
If you hit something in the water they are very easy damaged, i had heard that someone had shed a blade on a cnc aluminium prop as well.
I run some TJM aluprops and I like them very much. I'd run aluprops exclusively if they came in all sizes. The downsides (of which I experienced none) is just worth it to me, compared to spending hours on balancing, sharpening and polishing.
Old Sloppy
03-15-2012, 01:23 AM
Al. props are not the best, If sharpened the metal is too thin.
So don't sharpen them, only semi-sharpen Aluminum props.
that being said I ran an Al. x640 at Valdosta SAW races @ 62.517 mph and had no failures.
(yes, it was semi-sharpened at that speed)
