View Full Version : OSE BlackJack Conversion
04-29-2007, 01:51 PM
After a disastrous bench test with the stock drive I quickly found out that the universal will not take the power of bl or nitro.
I wanted to keep the scale looks of the steerable outdrive. Here's what I have done.
I removed the stock prop shaft.
Removed the stock bushings.
Drilled the stock out drive out to 1/4" or .250
Made a sleeve out of 1/4" k&S
Slide in a Stinger sleeve bearing, than cut it to the shorter length to fit the BJack.
Ran a new .150 cable with 3/16" prop shaft all the way to the new outdrive.
The new system is as smooth as butter!
I fired up a stock sv and a the sv powered Black Jack next to each other. The BJ is remarkably quieter than the sv. I hope to water test today! Pictures to follow in a couple of minutes.
Good Luck man!! I was hoping some one would try to improvre on the stock system. Do you have any ideas for a uiniversal upgrade? I had thought of modifieing a nitro or electric stadium truck mip cvd joint.
04-29-2007, 02:07 PM
Well I'm sure you could find some better universal but matting it to a flex will be no easy task. I have not water tested yet, but I can not see a downside to the outdrive mod. I cant wait to try it.
My mod will less than $20 !!!
.150 cable and shaft is $11
bushing is about $6.
1/4 k&s is about $2.
Of course this doesn't include the tools. But those I consider investments.
Oh ok now I get it. I was thinking somthing completly diffrent. Dude I wish I would have thought of that. Would have prolly saved me a ton of time and money finding a S&R setup that works. But I guess it a good thing I did the research. I hope to see some video:). Hey um I am assuming your keppin the radio box hu?
avengersteve
04-29-2007, 03:26 PM
im going to be trying the same set up.. thanks for the pics... what are you using for the motor mount?
04-29-2007, 04:08 PM
Radio box is staying. The mount is something I made. I need a new cad guy to draw it up for me.
Where you thnking of using the engine lugs like this boat. Or did you have a tunnel mount in mind?
Tunda
05-10-2007, 12:59 PM
steven did you run it yet?:D
rcBPman
05-23-2007, 10:08 PM
Steve.....send me some dimensions of that hull and mount you made or just give me a call and i can get it drawn in a few mins. All views and Isometric...3D CAD is on its way....my company is getting it very soon!!!
05-24-2007, 10:11 AM
Steve.....send me some dimensions of that hull and mount you made or just give me a call and i can get it drawn in a few mins. All views and Isometric...3D CAD is on its way....my company is getting it very soon!!! greg thanks for the offer. I will take it out and draw it when I get some time. Will you be in NH this weekend?
Tunda
06-02-2007, 01:09 PM
steven its been awhile did you run it yet let us know whats up.............ALOHA.....:D
06-02-2007, 03:19 PM
Nothing new, I have not run it since the last time.
I have a Blackjack Brushless that I ditched the universal and went with 3/16" flex shaft and 3/16" prop shaft. This looks to be a very good idea.
My problem is the prop to use. The prop that came with the boat for the smaller prop shaft is 1.6"x2.5" and 3/8" wide. I got a Graupner k series 54mm grp 2317.45 that is 1.77x2.48 that fits a 3/16" shaft. and it's is way too large when there is only 1/64" different. it's also 5/8" wide, thats 1/8" wider than the prop that came with the boat.
This prop is only 1/16" away from the water intake tube. That 1/64" differance to more like 1/8".
WHAT AREN'T I NOT SEEING HERE AND WHAT SIZE PROP DO I NEED.
Thanks
ISR
Rex R
01-26-2008, 07:31 PM
try a k-42 or an x642(sharpend and balanced octura)
TRUNKMUNKY
02-17-2008, 07:01 PM
Won't this not turn?:confused2:
I did this and it looks like it will work just fine!
Thanks,
ISR
02-29-2008, 06:54 AM
Several people have asked about the exact parts for this.
So here goes.
.150 cable, either assembled or unassembled. Depending on your ability.
http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc150L-24c
Stinger bushing
http://www.offshoreelectrics.com/proddetail.php?prod=ros-187sting-b
K&S tubing.
http://www.offshoreelectrics.com/proddetail.php?prod=dh-ks-brass-tb
One thing to remember this isnt a drop in system!
I long for the days of "drop in" upgrades :blink:
Eyekandyboats
03-01-2008, 10:15 AM
the ammo was a drop in for the SV
the grim prop was a upgrade
batteries are a up grade
I long for it too... :):P
FE Wannabe
04-24-2008, 05:29 PM
I am in the process of doing this same conversion on a Proboat Apache that has the same outdrive on it, only I am using a .130 cable with a 3/16" to 1/8" propshaft.
My question is, do you epoxy the Stinger sleeve bearing in the 1/4" brass tubing or do you leave it free spinning?
Question answered in another thread. Stinger sleeve bearing should be left free spinning.
