View Full Version : MHZ Mystic C5000 73" with twin 2028 12s
jdfenn81
03-08-2012, 08:24 PM
Okay guys
I am new here, but I have been building electric boats for quite some time now. I just bought the 73" MHZ C5000 from kevin on this forum. I think I got a pretty good deal and Kevin is a great guy.
Anyhow I would like to run twin castle 2028 both on 12s and 400a ESC from fighter cat. This leaves me with a bunch of questions.
1. What do you guys thing the top speed would be?
2. What motor mounts would you use?
3. Do you think the 400a ECS on each motor will run reliably?
4. Would you put water jackets on the motors?
Pics will come monday when the hull gets here.
Thanks
Jeff
srislash
03-08-2012, 09:02 PM
Wow! This'll be somethin.I just started with FC ESC's but all good so far.Benjamin is great to deal with.Where are you gonna find CR props for this beast.
I think I would build my own mounts or check out Bruisers build.His mounting system should do you.
http://forums.offshoreelectrics.com/showthread.php?30879-FC-Super-Daytona-twin-build
Are you going to water-ski behind,Hehe:lol:
jdfenn81
03-08-2012, 09:25 PM
Cr props, i had not thought about that. Any suggestions.
Pwb201
03-08-2012, 09:42 PM
What about MHz motor mounts for their in runner set? They come with a back brace for the long cans. All carbon fiber.. But pricey,you can relocate holes if not lined up I'm sure.
As far as props what about 447's, Evan 450 3 blades? Both sold here..think fighter cat may Evan have 4553 blades, good luck
Pwb201
03-08-2012, 09:45 PM
Btw once you determine props you can get idea of speed with the calculation page on this site. It'll give you rough estimate with one complete setup. And you'll be running two so I'd ad 5 to 15 mph although I'm just guessing there but it'll def be faster twins rock!
srislash
03-08-2012, 09:53 PM
I would think you would want at least 450's with 2028's.I may even hit them with my 37" Shocker(may try them).Bens got some sweet 1.8 series three blades(can you say AMPS). My detounged X447's aren't even working my TP 4082 motors.I know there are some German made props or the PropShop should have some.Check your choices and read the other twin builds before rushing out and buying props.They add up when you have to get 2 at a time.Since I started my twin build my prop box value went up about $400.
srislash
03-08-2012, 09:57 PM
Btw once you determine props you can get idea of speed with the calculation page on this site. It'll give you rough estimate with one complete setup. And you'll be running two so I'd ad 5 to 15 mph although I'm just guessing there but it'll def be faster twins rock! And sound so cool http://www.youtube.com/watch?v=XSfz7eL8t8s&feature=youtube_gdata
Pwb201
03-08-2012, 10:00 PM
Forgot this was 72" your right srislash, but still 12 s is high revs
srislash
03-08-2012, 10:03 PM
Forgot this was 72" your right srislash, but still 12 s is high revsSo will my TP 1810 kv on 6s or more.I have 642's and 645's for that.
jj2003
03-08-2012, 10:18 PM
Congrats on landing this beast Jeff! If I wasn't snoozing :sleep: I would have bought it! 12s may be a bit much for the 2028's. I'm building a 45" Speedfreak Hydro with a 2028 and I emailed Castle for some better details about the motor. Here was the reply
"John,
The 2028 is 780kv, and uses Neodymium magnets in a 4-pole configuration. In a car/truck application, the motor is warrantied to 8s, and in a proper boat set up, it is warrantied to 10s. The motor weighs 44 oz, but we do not publish any amp ratings or resistance to the public.
If you have any further questions, please e-mail or call the Tech Support line below.
Greg Wright
Product Specialist
Castle Creations
540 N Rogers Rd
Olathe, KS 66062
913-390-6939 ext 138 (tel:913-390-6939 ext 138)
greg@castlecreations.com "
I still haven't been able to find a max amp rating or resistance #'s. If your not worried about warranty then 12s them. But I wouldn't expect to have Castle cover them if they blow. Myself, I'm going to run a pair of TP5000-10SPP65L 5000mAh 10-Cell/10S 37V in 10s2p for a total of 10000 mah. It'll be covered under warranty if I blow it as I'm going to document it and send a list to the Rep for registration. I haven't seen anyone else push it to 12s yet and I think there is a reason why. Just an awfully expensive motor 2 cook!
jdfenn81
03-08-2012, 10:50 PM
Are there any motors out there that can take 12s
nata2run
03-08-2012, 10:55 PM
Jeff, Congrats on getting this beauty!!
Firstly 780kv on 12s will give you 39K'ish is unloaded. Thats fine!! I would not worry at all. However 73" is a big hull, and will take alot of power to get going fast.
If it was mine I would not use the "traditional way" of mounting motors but rather have mounting plates in the sponsons bottom. Similar to Christians "Golddigger"
72123
Make-a-Wake
03-08-2012, 11:16 PM
jdfenn, i own a couple Castle 2028's and run them in a 47" Mono on 10s2p and a 50" Hydro on 9s2p. I would not run more than 10s. I'm spinnin' an x457/3 on the mono and a cut down s270 Prather on the Hydro. I'd suggest 10s2p(or 3p) and use larger props...............something in the x455/3 or x457 range.
jdfenn81
03-08-2012, 11:23 PM
What is the absolute most powerful electric setup for this boat?
nata2run
03-08-2012, 11:33 PM
Maybe LMT 3080/8 would give you some nice power (656kv)
Make-a-Wake
03-08-2012, 11:34 PM
Twin 2028's is bordering on Insane..................i have logged 8300 watts on my 2028............two would be around 22-23 horsepower!
The only motors I can think of that would be more "insane" would be twin Neu 2230's......................Possibly the Big Lehner 3080 as well.
nata2run
03-08-2012, 11:38 PM
This is from a German site:
owner: Herrms
design: Pair a Dice
hull: HPR 233 CFK
engines: 2x LMT 3080/9
controller: 2x Schulze 40.160WK
lipos: 2x 12S4P Kokam 4000 30C
props: Octura X465
speed: 140 km/h
nata2run
03-08-2012, 11:41 PM
Expect something like this : http://www.youtube.com/watch?v=7rvzYgF28JE
srislash
03-09-2012, 04:54 AM
The only motors I can think of that would be more "insane" would be twin Neu 2230's......................Possibly the Big Lehner 3080 as well. I went checking out Neu's site and the 2200 series should have something for you.http://www.neumotors.com/Site/2200_12_series.html
jdfenn81
03-09-2012, 01:06 PM
Okay
After looking around this is the setup I think I am going to go with.
2 NEU 2230 725kv
4 6s 5000mah
2 fighter cat ESC 16s 400a
2 CR props from MHZ racing
2 Carbon motor mounts from MHZ racing
2 Direct drives from MHZ racing
Pwb201
03-09-2012, 07:27 PM
That's awesome!! Great decision!! Not to change mind but have you looked at there line of scorpion motors? MHz has their own custom line that Really sweet. Might Evan be cheaper than nue, I have two sets in two different hulls of the 3026 which is the smallest version. And they are way under rated in power I'll say that confidently.. http://www.mhz-powerboats.com/mhzpowershop/artikelueber.php?wgruppeid=1277&wgruppe_offen=1277&sid=95cd2ed1c08be6feaf4384f176b3d1b8
Well they might be cheaper if sold in states:)
srislash
03-09-2012, 08:01 PM
Okay
2 NEU 2230 725kv
4 6s 5000mah
Man this is going to be SAWEEET
While you're at FC you might want some of those 1.8 props.
Make-a-Wake
03-09-2012, 08:49 PM
Okay
2 NEU 2230 725kv
4 6s 5000mah
Going the el cheapo route i see.........................
Very nice components there.............What props? The 67xx series are 3 blade cleavers......................
jdfenn81
03-10-2012, 03:43 PM
Does anyone know where to buy these NEU motors. I have found one in stock and need a second.
Jeff
Make-a-Wake
03-10-2012, 07:20 PM
This store has all the 22 series..................2215, 2217, 2220, 2225, 2230
http://www.cermark.com/products/NEU-2230-series%3A725kv-or-1Y-winding.html
