View Full Version : Poly Rc 4s cells 5000mah lazzy ?
lenny
03-05-2012, 08:13 AM
Hi,:tiphat:
I just bought two used poly rc 4s 5000mah cells from a Ose member,
He said they would not be good for racing, But would be good for sport running.
Also he said they have bin in storage 8 months.
I charged them and #1 cell read 420,419,419,419, 16.79 volts and # 2 cell read 420,420,420,419, 16.79.
Tried to run them in stock P1 kos 35" stared out slow and lv kicked and it set at 3.20,
So I reset it to 3.00 and same thing happened.
Could the cells just be lazy and need to be cycled a few more times,Or are they done ?:noidea:
I charged them again, And all the cells read the same as before.
But this time I ran 4s1p and the boat ran slow gps at 25 mph,
And if do not baby the throttle lv kicks in.
The other 4s cell is a little better, I gps 28 mph.
Thanks for any input.:beerchug:
oscarel
03-05-2012, 08:46 AM
I think I may have the same issue. I only tried 1 run with them though.
Make-a-Wake
03-05-2012, 09:11 AM
What ESC?
lenny
03-05-2012, 09:37 AM
Stock p1 60 amp, I think it the 60 amp seaking because the program card work on it.
I tried setting the lv to 3.0 but it still kicked in if I do not baby the throttle.
All my other cell work in boat, My 3s I get 29 mph and 4s I get 39 mph.
oscarel
03-05-2012, 10:42 AM
Fyi for the price paid I'm not complaining.
lenny
03-05-2012, 10:49 AM
Did yours run the boat like a 2s 3s pack or a 4s pack ?
I just thought that they should run the boat.
oscarel
03-05-2012, 10:59 AM
Rrr
lenny
03-05-2012, 11:12 AM
Rrr
Yes, http://forums.offshoreelectrics.com/showthread.php?32220-Used-4S-Lipo-5000mAh&highlight=5000+cells
jcald2000
03-06-2012, 07:19 AM
Lenney, isn't it still cold in NJ?
If the battery temp wasn't above 85 degrees when you put them in the boat they won't put out full voltage.
oscarel
03-06-2012, 03:14 PM
I believe they're just about used up. Left is 4s2p Polyquest 5050 35C and right are the Poly RC's.
71992
lenny
03-06-2012, 06:10 PM
71992
Ok thanks for that info,
By the way what was the temperature there today ?
oscarel
03-06-2012, 06:33 PM
It was around 65 or so. Shouldn't have that much effect on them, the others ran fine.
johnnyoverkill
03-06-2012, 09:26 PM
I bought the other 6 batts guys. I'll do a charge & load test in the next few days, and I'll let you know how mine do. Remember, Randy said that they were sitting for quite a while. Cycle them a few times and see what you end up with. I'll drop you both a line with the results from mine, sometime this upcoming weekend.
John
:spy:
lenny
03-07-2012, 10:04 AM
Hi,:tiphat:
Lucky you, :just-kidding:
The two packs I got from him were marked with tape and one read 15.95 w 76%,
And the other read 16.21 w84%.
What does the tape read on the packs you guys have ?
It took me 10 hours to balance one of the pack 1c,
The other one about 2 1/2 hours.
Let me know how you guys make out.:beerchug:
johnnyoverkill
03-11-2012, 10:00 PM
Ok guys,
I picked 2 of the 6 packs at random, charged them on my Hyperion Duo, and ran the crap out of them. They wouldn't hold up as race packs, but they'll work fine under low to medium amp draw. All in all, they'll work fine for what I bought them for. Good luck with your packs guys.
John
:beerchug:
lenny
03-15-2012, 08:42 PM
Dissatisfaction with RRR 5000mah cells.http://forums.offshoreelectrics.com/showthread.php?32220-Used-4S-Lipo-5000mAh&highlight=5000+cells
Like I said, Lucky you.
Oscare said he was going to dump his in the trash,
They were unuseable to him.
Mine on a stock P1 KOS 35" with a x440 prop will go to lv if you do not baby throttle at 1/4.
I think the add description for sport use not racing, Should have be good for trolling use.:ThumbsDown01:
johnnyoverkill
03-15-2012, 09:07 PM
Have you tried cycling them a few times first? There is no punch left in mine to be honest, but my plan was to use them to power some old brushed set ups. For that they were fine. In truth, I ran the packs as 4s2p on an old SS1 set up, and it ran wide open throttle for 10 mins. Granted, it was running on a x442 prop, and the batts came in luke warm, but I believe there is some life left. On a stout brushless set up I have no doubt that they would immediately fall flat on their face. Again, I didn't buy them for that, I have my Hyperions to run my Nue motors on.
I do wish you guys luck. Maybe give some thought to saving them for a kids boat on low power, or a scale project. Get your money's worth before you can them!
John
lenny
03-29-2012, 12:45 AM
Well paypal claim has been sent.
So much for luck,
Oscarel I have your back.
