View Full Version : Segad is slow...
Rob DeAngelis
02-24-2012, 08:59 PM
Damn you would think that there would be more speed to this thing... handles great and all but my spartan and MC both can lap this thing... any suggestions to get more speed? ive done everything I can... running parralel 3s lipos with the stock 2700k motors and 60 amp esc's...:huh:
Alexgar
02-24-2012, 09:08 PM
4s or bigger props
Make-a-Wake
02-24-2012, 09:38 PM
It wasnt engineered with big speed in mind with those smallish motors. A pair of these on 4s each would get it rockin'!!:rockon2:
These are 4 pole motors btw: http://www.hobbyking.com/hobbyking/store/__17730__XK2860_B_2200KV_Brushless_Inrunner.html
Hoverdown3k
04-27-2012, 02:38 PM
No need to replace motors, go to 4S Lipos and get the venom CNC props or anything but the stock plastic props, you will see a big difference in speed.
forescott
05-08-2012, 05:08 PM
just be sure to get the 32mm props if your gonna run 4s with stock motors. The 36mm props might be pushing the limits of the stock components.
Paul Susbauer
05-17-2012, 07:15 PM
Forescott is correct. Make sure you are running the 32mm props.
Paul Susbauer
Venom Group International
tryinotocrash
06-17-2012, 12:45 PM
So these will run the 4s if you run with the 32mm props ? anyone had success with this setup? Not looking for blinding speed just something fast and still reliable. Stock motors stock ESC's . It seems to run well on 3s with the 36mm aluminum 3 blades. Sanding the bottom of the sponsons seemed to free it up a bit more.
