View Full Version : Impulse 31 bouncing baby boy
Skullcracken
02-22-2012, 09:16 PM
I know guys have already commented on this but crap. I have adjusted the COG, I've adjusted the strut - what helps this thing's bouncing. I wouldn't call it porpoising, it pops up out of the water fully , instead of bobbing up and down at the front like when boats porpoise. I've seen vids with this thing glued to the water. Can't figure out how to keep it down.
roadrashracing
02-23-2012, 10:01 AM
On mine I found the best way it ran at higher speeds was the trim tabs just bent down a little, bit.
Darin Jordan
02-23-2012, 10:47 AM
What prop are you running??
At certain speeds, it gets to the point where the lift of the hull is too much for the power. When you hit that point, the solution is to add weight to the centerline on the CG... When I run mine in P-Mono, I run 4S2P and an additional 6-12oz of weight added under the battery tray or just aft of the motor.
Bullwink
02-23-2012, 10:59 AM
Darin what prop are you running in P-Mono?
Darin Jordan
02-23-2012, 11:09 AM
That's not a safe question for me to answer at this point.... Thus far, I've been playing with motors and most of what I currently have has been way too "hot" for an actual P-Mono setup.
The one setup I used that does work is the Losi Xcelorin 1/8th scale buggy motor @ 2100KV. Nice motor. 4-Pole, has HUGE 8mm shaft, turned down to 5mm, so solid bearing setup. With this motor, I was running an X447/3 and having decent results.
Again, I'm still playing with these setups and certainly don't have all the answers for the higher power stuff in this hull. Like I mentioned before, it's designed for P-Ltd power and to work well in the power range. When you start adding more power, you'll need to add some weight as some point.
Skullcracken
02-24-2012, 09:58 PM
First just tinkering with it stock everything. Bounces on 4s and 5s. I have a leopard 2200kv on the way. I've bent the trim tabs down some, but I didn't want to over do it and kill speed with drag. I've moved the lipos forward and adjusted the strut positive. Trying negative initially made it worst. Don't know. In any turn, slight or hard, doesn't bounce at all.
Skullcracken
02-24-2012, 10:00 PM
How are you increasing prop size? Did you change out the rudder assembly? In a full left turn, my 40mm prop is very close to the rudder, and a 42mm nearly touches the rudder. (Bench tested)
de-pro
02-25-2012, 08:26 AM
it shouldnt be. this is a 447 prop in the picture
71265
de-pro
02-25-2012, 08:28 AM
71265
71266
stadiumyamaha
02-26-2012, 10:21 AM
It depends on your steering rate. I have to turn mine down when running a larger prop. Found out the hard way too.
Skullcracken
02-26-2012, 11:11 PM
[QUOTE=de-pro;395817]it shouldnt be. this is a 447 prop in the picture
Have you rotated the prop so the blades are horizontal and turned the rudder fully left and looked? This is the stock 40mm prop, probably only about 3mm's from touching the rudder... Looks like I could only go up to a 42mm prop, unless I sacrifice turn endpoints and lose maneuverability.
71383
Skullcracken
02-26-2012, 11:14 PM
Posted before I saw your reply. Thats what I figured. Don't know how that guy is using a 47mm prop though. I don't want a 30ft turn radius...
Skullcracken
02-26-2012, 11:18 PM
Fixed the bouncing. I increased the positive on the strut, and bent the trim tabs to the point where they are level with the bottom of the hull but mounted a couple of mm's higher than the bottom. (meaning bottom of the hull relative to the location of the mounts - obviously not the actual bottom at the apex of the "V" bottom) No more bounce but seems to be a good amount of drag. Noticeably slower.
Skullcracken
02-26-2012, 11:31 PM
71265
Actually looking at this angle, maybe the longer length of a bigger prop would extend the blades past the rudder?
de-pro
02-27-2012, 10:38 PM
Steering rate at 100% and no it doesnt turn like a Mack truck :)
Here is some more photos
7145671457
Skullcracken
02-28-2012, 07:52 PM
7145671457
Good to know. I've been wanting to go up to an X445 but thought anything bigger would touch.
