View Full Version : Right props 44" mystic??
Pwb201
02-21-2012, 02:38 AM
I currently own 442's 447's but am looking for a good 3 blade to add into my collection.. Any suggestions?
Also where to buy thanx everyone!
battlefury
02-21-2012, 03:41 AM
fightercatracing.com
Pwb201
02-21-2012, 09:27 AM
The smallest size I see is 50mm? I have a set of those as well and think they might be too big, looking for a little smaller but thnx
battlefury
02-21-2012, 09:57 AM
How about abc props from uk? They have a wide variety of props available
LarrysDrifter
02-21-2012, 10:05 AM
What motors do you have? Voltage? Top speed runs, or sport running? If you want more props just to own more props:
http://www.offshoreelectrics.com/proddetail.php?prod=abc-1816-10-50%283%29CLL
Pwb201
02-21-2012, 05:44 PM
2 Scorpion 3026,2300kv 200amp esc's will run 4,5,and 6cell lipos depending on props
Like I stated up top Larry looking for a pair not a single... Want to lift the rear of boat up for top speed runs hence 3 blades, not looking "more props just to own".
LarrysDrifter
02-21-2012, 05:58 PM
You can get them in left and right rotation. Nobody can suggest any prop at all with out knowing what voltage will be run. If youre running different voltages, then use the 442's for 6s. Try either the 447 or ABC's on 4 and 5s. It does help to be specific with your set up and intended use of the boat.
LarrysDrifter
02-21-2012, 06:01 PM
Heres the right hand
http://www.offshoreelectrics.com/proddetail.php?prod=abc-1816-10-50%283%29CLR
Since OSE is out of them, www.rocketcityracing.com may have them in stock. If they are out, just look around. Maybe pm Dasboata or email him, as he might stock some props.
Pwb201
02-21-2012, 06:05 PM
Thanks Larry
