View Full Version : Stock ESC and motor?
alvinm
02-17-2012, 10:31 AM
I posted this question in another unrelated thread, so I figured I'd get a quicker response here..
Will the stock setup handle two 3s lipo's, or a 3s and a 2s with the same mah?
DjFlipNautikz
02-29-2012, 11:52 AM
don't take my word for it but if i am not mistaken i read that it can handle upto 5s if you install a UBEC or if you remove the red wire from the connector of the esc to the reciever and install a seprate RX battery pack.
my friend however which is on here told me he tried 5s with out any modifications and that everything ran cool.
but i am a n00b so hopefully some more experienced people will chime in.
Good Luck
dana
02-29-2012, 11:58 AM
6s no. The motor will handle 5s but I'm not sure about the esc. 2s+3s same mah ok
longballlumber
02-29-2012, 12:47 PM
I would suggest to stick with 4S otherwise you will run the risk of failure or shorten the life of the motor.
Later,
Mike
alvinm
02-29-2012, 01:01 PM
Its plenty fast with 4s, its just that I have an extra 3s pack I would like to use..
Make-a-Wake
02-29-2012, 01:27 PM
Try the stock setup with an x640.................... If you run a 2s and a 3s they need to be the same mah and "C" rating!
DjFlipNautikz
02-29-2012, 03:29 PM
I have a question. I run my MC parallel instead of series so i have two Turnigy 4s batteries 5000mah. BUT they are slightly different C rating one is 25c- 35c and the other is 40c - 50c
is that a problem? even though i think it is a little late for that as i have already ran my MC about 10 times with those packs.
Make-a-Wake
02-29-2012, 04:20 PM
It could cause a major problem right off the bat or it could abuse one batt that it will eventually give up, bloat, or explode...................
DjFlipNautikz
02-29-2012, 04:39 PM
Well I check the temps of the batteries. I usually only do a run of like 8-10 mins and the temp is always about 100* - 110*. Would it be better if I run on battery at a time? Even tho it's a hassle to re tape and stuff.
alvinm
02-29-2012, 09:50 PM
I'm using the Grim 42x55 prop now, will the x640 perform better?
Rob DeAngelis
03-05-2012, 09:07 PM
I ran a 5400mah 3s 20c and a 5400mah 2s 20c and had no problems... everything was cold after a w.o.t. run for about 5 mins... and I havent even upgraded cooling...
Rob DeAngelis
03-05-2012, 09:08 PM
I ran a 5400mah 3s 20c and a 5400mah 2s 20c and had no problems... everything was cold after a w.o.t. run for about 5 mins... and I havent even upgraded cooling... btw im running the grim 2300kv instead of the regular 1800kv if that makes a difference, idk...
cpgise
03-05-2012, 09:23 PM
Is that the ammo motor?
Rob DeAngelis
03-06-2012, 08:43 PM
no its the stock AQ motor thats in the UL-1...
Rob DeAngelis
03-08-2012, 03:59 PM
btw its a 2030kv... not a 2300 like i said... typo :doh:
gek1946
11-09-2012, 08:10 PM
can you safely run the motley crew on 5s without any modifications and can you still use deans plugs
