View Full Version : You think these props would be to big.
floatn turd
02-15-2012, 12:36 AM
What do yo think of these props for the following set-up?
MOTOR: TP 4050 1160kv
ESC: 2s-8s 240amp by fightercat
HUll: Motley Crew
Props: Prather SS Prop S-255
Prather SS Prop S-260
Octura 2 blade prop X572
Octura 3 blade prop X670
You think they are too "big" for that set-up?
thanks
Chilli
02-15-2012, 08:21 AM
I'm not familiar with that motor and don't know what batteries you'll be running but 70+mm props are WAY big for that size hull. You usually find them in 45 inch gas boats. My guess is the boat would handle terribly. Plus those props are only made for 1/4 inch prop shafts. You'll want the RPM about 30k unloaded (+/- a couple hundred) and a prop size in the 40's
Make-a-Wake
02-15-2012, 08:54 AM
Yes, too big.
floatn turd
02-15-2012, 11:37 AM
Perfect, thanks for the response guys.
