floatn turd
02-13-2012, 09:43 PM
I have heard a few different things. Is this true?
You must select the charge rate current that does not to exceed 1C (one times the capacity of the battery). A higher setting may cause fire.
Example:
1900 mAh: Charge below 1.9 Amps
2100 mAh: Charge below 2.1 Amps
7800 mAh: Charge below 7.8 Amps
8000 mAh: Charge below at 8 Amps
But I have also heard that you can go higher (charge CAP) if the battery is a "quality" battery.
I have a Gensace 5300mah 35c. 2s,3s and 4s batts, With a Venom dual 10a charger.
So is it true that I can only charge 5a max,on my Gensace?? and should not use the full 10a of my charger??
thanks
Example:
thanks
