View Full Version : Seaking 180 amp esc question
darrin4800
02-13-2012, 07:53 PM
I have a new 180 amp seaking esc and when i plug in a battery a red light blinks and it doesent do anything.
Help. Thanks.
rc2266
02-13-2012, 08:02 PM
Got programer?
darrin4800
02-13-2012, 08:29 PM
Yes I do.
de-pro
02-13-2012, 08:37 PM
Is it connected to a receiver. Did you bind the receiver to your radio (spektrum only)
darrin4800
02-13-2012, 08:54 PM
I just have the motor pluged in and a battery.
de-pro
02-13-2012, 08:59 PM
If you have the program card then its all you need, otherwise you will obviously need a radio to do anything else with it
darrin4800
02-13-2012, 09:02 PM
I cant get the programing card to work.
battlefury
02-13-2012, 09:35 PM
Just removing the red( postive wire) from the RX plug(ESC) and supply an external power source to ur reciever.
Most probaly, ur internal BEC is disfunctional. And set your Lipo cut off to non but monitor your run time
runzwithsizorz
02-13-2012, 10:08 PM
There should be no need for him to remove the red wire, YET. WE, do not know his boats, and radio specs, how much experience he has, if he knows how to *properly* remove the red wire, if he is inserting the plugs correctly, if he even has an RX battery,
if he has the instructions. Always advise someone as if they were a complete noob, unless you know otherwise.
Take your time OP answers will be forthcoming.
de-pro
02-13-2012, 10:20 PM
connect the wire from your esc to the top right connector on the programmer with your black negative wire being the first one on the left
Plug in the power to the esc and wait for a few seconds. The programmer should light up and then follow the instructions on your programmer
pyroM!KE
02-13-2012, 10:53 PM
Help. Thanks.
If your running a futaba radio or similar, reverse the throttle channel..Try it..:thumbup:
battlefury
02-14-2012, 03:41 AM
Sure thing, Darrin when you have those 'gray' areas as he pointed out competent enough you can then perform whatever remedy that discussed in here. I agree with runzwithsizorz he is just being concerned. the advice i gave is because the similar issue has occur to me twice before on turnigy 180 and SK180 . it did work at least to me.
darrin4800
02-14-2012, 10:37 AM
Thanks to all.
darrin4800
02-14-2012, 02:05 PM
Thanks battlefury you are the winner. You were right the bec has A problem, I put in an external one and it works fine.
Thanks again for all your help Darrin.
battlefury
02-14-2012, 07:56 PM
:hug1: Good Job!
