View Full Version : Need help to understand Parallel Deans Plug
tlandauer
02-13-2012, 02:53 AM
I am trying to increase run time by hooking up two 3s lipo for Venom KOS P1. I only want 11.1v, so no mysteries there. The thing I am so puzzled by the fact is that the ESC won't arm once the batteries are pluged into this contraption that is made by GreatPlanes. I am attaching a photo. I bought a second one thinking the first was defective. I used a multi meter to test and all plugs are showing voltage. :confused2: 70382
tlandauer
02-13-2012, 10:05 PM
somebody has got to have an intelligent answer to this, I might have posted here in the wrong place, but any advice would be greatly appreciated.
lenny
02-14-2012, 09:36 PM
Do you have a multimeter to test for continuity at - and + sides of the new plugs ?
The plug both batteries into the new parallel plug and test for volts, You should have 11.1 v,
But I would ditch the dean plugs.
And go with 5.5 bullets, Just a lot better setup all around and less resistance,
That will give you more power in the long run and cooler temps to.
