View Full Version : Lipo Salvageable?
DjFlipNautikz
02-13-2012, 12:44 AM
So I have a 3s turnighy 5000mah battery that was knocked around inside a Spartan after it launched in the air at full speed and tumbled. When I checked the taps the middle cell does not read in my meter and when connected the battery shows as 0 volts however when I check the taps the first and third cell show fine. I'm guessing it's wire connection got knocked off. Can I fix that?
Diesel6401
02-13-2012, 12:52 AM
Yea it's it's prob fixable, the question is are you up to it? Tearing down a lipo and directly soldering on the tabs is a dangerous job. When I do it I make sure I have a fire extinguisher standing by. Chances are one of the balance leads got destroyed. IF you decide to do it, please be careful. You can check the voltage of each cell when you undo the wrapper and expose the board. If all cells measure fine directly to them, bypassing the balance tab, chances are it's a bad plug or loose connection on the plug (balance plug). I have had some crappy soldering jobs on the Turnigy packs. The value is awesome and they work great, but the soldering and QC is sub-par. I did a video on repairing a Turnigy pack, click the youtube link in my signature.
DjFlipNautikz
02-13-2012, 10:09 AM
Is it a big deal? I have gotten kind of good with soldering so i think i can do it.
Diesel6401
02-13-2012, 12:19 PM
Yes it is a very big deal. Lipo's if shorted or mishandled can potentially become a fire ball.
Drax21
02-13-2012, 12:23 PM
The big packs are like C4 but a bit more...SPARKY:flashfire:
Take care
DjFlipNautikz
02-13-2012, 01:11 PM
Ok. I will take a peak and if I think I am able to do it I will. Thanks again
Diesel6401
02-13-2012, 04:11 PM
Let me know what you come up with. If you don't feel up to it I might be able to take a look at it if it's in my comfort zone.
DjFlipNautikz
02-13-2012, 04:24 PM
i am going to open up the lipo where the connections are soldered and take a picture so you can see. probably do that tonight when i get home.
Diesel6401
02-13-2012, 05:40 PM
That's cool. I'm friends with the owner of the lhs and they had a lipo sitting off to the side I asked what the deal was they said it wasn't registering any voltage, I brought it home and just repaired it now. Free lipo woohoo. I checked the voltage to each individual cell and they all read 3.8v per cell which is perfect I then measured voltage at the discharge/output wires and it measured 0v total I then used thed balance tap and it also read 0v that told me the series circuit was open somewhere after searching the board I found where the problem was. Seems the batt may have been shorted out and blew out a connection point. 30 seconds of soldering and back to new! Took 5-6m total!
Sent from my T-Mobile G2 using Tapatalk
Drax21
02-13-2012, 05:42 PM
It is pretty easy really. :thumbup: for getting a free lipo!
DjFlipNautikz
02-13-2012, 05:57 PM
SO i opened the top up just like you and can't seem to find anything. I still left one of the protective plastics on but you can see.
The second picture shows where i place the wires of the voltage meter and get 0 volts.
as you can see in the picture i have in order BLACK, YELLOW, BLUE, and RED wires. When i test black & yellow its fine. test yellow and blue its 0 volts, blue and red fine. But then i check BLACK AND RED and it says 0 volts... whats going on here??
http://farm8.staticflickr.com/7056/6872268173_18bb361a57.jpg (http://www.flickr.com/photos/45552410@N07/6872268173/)
IMG_2419 (http://www.flickr.com/photos/45552410@N07/6872268173/) by Djflipnautikz (http://www.flickr.com/people/45552410@N07/), on Flickr
http://farm8.staticflickr.com/7059/6872268971_2343712a3d.jpg (http://www.flickr.com/photos/45552410@N07/6872268971/)
IMG_2421 (http://www.flickr.com/photos/45552410@N07/6872268971/) by Djflipnautikz (http://www.flickr.com/people/45552410@N07/), on Flickr
Diesel6401
02-13-2012, 06:48 PM
The fact your reading 0 at the output cables (red/black) or your traxxas plug, indicates it's a open circuit. If just a cell was dead the output at the cables should read as a 2s instead of a 3s pack. There has to be a very VERY small area that doesn't connect.
DjFlipNautikz
02-13-2012, 06:54 PM
But why does it read with black - yellow & blue - red but NOT blue & yellow? Do I have to open it up completely?
rc2266
02-13-2012, 06:56 PM
Not to highjack, but if I send you one how much would you charge for a repair, I shorted one out and I know I prob have a crack in a solder connection
Diesel6401
02-13-2012, 07:16 PM
The connections should be exposed and you read directly at that point, move all that yellow wrapper outta the way.
Diesel6401
02-13-2012, 08:18 PM
Who me?!?
DjFlipNautikz
02-13-2012, 08:42 PM
I touched the solder point of both the yellow wire and the blue and still get 0 volts
rc2266
02-13-2012, 08:50 PM
Who me?!?
Yes you, sorry was sending from cell phone.
Diesel6401
02-13-2012, 09:15 PM
sounds like you may be going from 1 negative to another,or if the crash was really that violent I wonder if one of the cells pulled away from board. Don't focus on the actual balance tap wires, your focusing on the cell solder points itself.
Diesel6401
02-13-2012, 09:18 PM
Well just pay for shipping to and from and I can look at for you. Not promising I can def fix it, but i'll look at it for you and if I can repair it I will.
rc2266
02-13-2012, 09:38 PM
Can u pm me an address? And I'll send it to you and see what happenns
