View Full Version : 24 inch plywood cat
boatbandit2
02-07-2012, 09:25 AM
Hi
Heres some pictures of my build so far i have laminated some carbon fibre on some frames i have purchased a Proboat brushless motor
boatbandit2
02-07-2012, 09:27 AM
Some more build pictures
boatbandit2
02-07-2012, 05:55 PM
Hi i was wondering if you use a single drive line do you fill in the spacers at the rear of the boat that are use for twin set up?
Cheers
Paul
rcboatmanwithkids2880
02-08-2012, 10:31 PM
Hi Paul ,
Wise move to build a single drive , as you have half the cost & half the maintenance involved as with a twin . Without seeing the rear of the hull where you are talking about , I would say if the twin spacers are causing concern in any way then do something about it . You do not want to build unwanted weight into your build if it is a fairly big hull , then inherently it will be relatively heavy .
Interested in knowing what brand of hull it is , as the tunnel doesn't seem so deep ?
All the best with the build .....
Brad
Oz
02-08-2012, 10:37 PM
Hi Paul ,
Wise move to build a single drive , as you have half the cost & half the maintenance involved as with a twin . Without seeing the rear of the hull where you are talking about , I would say if the twin spacers are causing concern in any way then do something about it . You do not wanted to build unwanted weight into your build if it is a fairly big hull then inherently it will be relatively heavy .
Interested in knowing what type of hull it is , as the tunnel doesn't seem so deep ?
Brad
Oz
boatbandit2
02-10-2012, 12:03 AM
Hi Brad
I have uploaded a photo to show you where i am talking about the plans are from Lomdel he has been building a 770mm long cat
mine is 600 long i hope i will go hard
Cheers
Paul
Chrisg81983
02-10-2012, 12:54 AM
Very nice, and good luck. Chris g
boatbandit2
02-10-2012, 04:06 AM
Thanks Chris
I hope it will go well
Paul
boatbandit2
02-20-2012, 06:47 PM
hi
Some updates on my build
boatbandit2
02-20-2012, 06:48 PM
Some more
Boaterguy
02-20-2012, 07:23 PM
climbing aboard :tiphat:
boatbandit2
02-22-2012, 05:44 PM
Picked up my hardware but i was wondering if i should build a stand off bracket i have this strut Product ID: oct-oc6str-130a
Octura Inline Rudder System
I have never setup a cat before please :help: me
boatbandit2
02-25-2012, 03:50 PM
CAN SOMEONE PLEASE HELP ME :help: ME
Chrisg81983
02-25-2012, 04:40 PM
I would give it a try I used standoff brackets a few times on my cats and it made a big difference in handling on two of my boats and on one it made no difference at all but you might want to get other opinions I am not sure how it will work with your hull I am not a fan of inline setups but that's my own opinion good luck
Chris g
chris reed
02-25-2012, 07:12 PM
Hi where did you get the plans for the boat. I would like to build one.
boatbandit2
02-25-2012, 09:34 PM
Hi have alook at 30inch cat build Jesse on there help me
boatbandit2
02-25-2012, 09:42 PM
Chris g
Hi Chris
I could make it not a in line system do you think this would be good Product ID: oct-oc6str-130da
Octura Offset Rudder System
Cheers
Paul
boatbandit2
02-28-2012, 03:44 PM
Some more photos made my own offset shaft yesterday lathe up a couple of diff lengths
