View Full Version : seaking 180
Just installed a 180amp Seaking and my question is how do you not have to go into throyyle setup everytime you power everything up? Tried shutting off the reciever first, the transmitter first , ran a seperate battery pack to the reciever and shut down a few other different combinations..... still have to go to throttle mode setup each time I repower. What did i miss? Thanks
Alexgar
01-28-2012, 06:06 PM
my turnigy doesnt do that maybe somethings wrong with it
carlcisneros
01-28-2012, 10:08 PM
first off did you calibrate the Throttle?
THEN, did you actually program it?
Calibrate first, programming second.
Very important.
if you run a seperate battery for the receiver, make sure and remove the RED WIRE from the plug going to the receiver from the ESC.
Boaterguy
01-28-2012, 11:06 PM
if your throttle channel is reversed, it will recognise it at full throttle on power on which brings it into program mode.
All set. I did the program again but also my throttle trim was also to high. They where set for my Castle controllers. Thanks guys.
