View Full Version : A little LIPO question...
Rob DeAngelis
01-27-2012, 08:42 PM
Please help me find a 3s 5000mah 40c.... I cant find one anywhere!!:frusty: Im trying to get 5s with the help of a Grim 2s 5000mah 40c.... any suggestions????
Rob DeAngelis
01-27-2012, 08:47 PM
as for the turnigy batts...no thanx... to many bad reviews...
GTRhino24
01-27-2012, 09:04 PM
Zippy makes one. I've been happy with the Zippys I've bought.
http://www.hobbyking.com/hobbyking/store/__16788__ZIPPY_Flightmax_5000mAh_3S1P_40C_USA_Ware house_.html
Rob DeAngelis
01-27-2012, 09:29 PM
good price as well... thanks man, I got 2 on the way already!!! :beerchug:
Boaterguy
01-27-2012, 09:30 PM
don't combine a grim racer with a zippy, even if they are made in the same factory, the cells won't be matched and are likely not even made identical, especially if you have used your 2S pack and broken it in.
http://www.hobbypartz.com/77p-sl5000-2s1p-40c-2222.html
http://www.hobbypartz.com/77p-sl5000-3s1p-40c-3333.html
go with those or the more expensive gens ace from the same site for higher performance.
Make-a-Wake
01-27-2012, 09:31 PM
Out of how many are sold i bet the 'bad' reviews equal about .000001% of 'em. I have dozens and never had one "go bad".
I have Zippy/flightmax as well, like them just fine too.
Boaterguy
01-27-2012, 09:41 PM
i have had 6 zippy's, a total of 17 cells and one of them was bad, so a 94% success rate.
I went with gen's ace packs instead, i still have 3 of the 4 3S packs.
i'm not saying don't go with zippies, or turnigy's for that matter, i have a 3S basher pack that has been shorted (accidentally) countless times and still runs fine.
Just DO NOT MIX DIFFERENT PACKS.
GTRhino24
Also, if you're dead set on running 5s, I run 5s Zippy Flightmax 3000mAh in parallel. You'll have to solder new leads to your ESC, but it's a good excuse to go ahead and swap everything to 5.5 bullet.
Rob DeAngelis
01-27-2012, 10:39 PM
cool... looks like I still have more homework to do... thanx for the info...
cuppa
01-28-2012, 02:29 PM
I have 3 packs of 5800mah 2s Zippy's and they are fine.
Good advice about the 5.5mm bullets
