View Full Version : Can I use a 24V power supply with any charger?
Drax21
01-25-2012, 12:30 PM
Question as above. I know most chargers only require 12V but will it hurt to use a 24V 13Amp power supply? Will this help balancing?
Thanks
RaceMechaniX
01-25-2012, 01:27 PM
DO NOT USE A 24V POWER SUPPLY ON A 12V CHARGER! Unless you charger is rated at 24V input you should stay below the maximum input voltage. If you apply 24 volts to a 12V charger be prepared fro smoke.
Drax21
01-25-2012, 01:31 PM
Thanks for your reply. Please check this vid. Tell me what you think. http://youtu.be/sJsgJlGN7kk
RaceMechaniX
01-25-2012, 01:35 PM
The 208B according to its input specs is good from 4.5VDC to 32VDC so a 24VDC power supply is suitable.
Drax21
01-25-2012, 01:39 PM
Thanks. It does seem to work good in that vid. I hear balancing on that charger is amazing and was wondering if I should get the same power supply. Q answered thanks
RaceMechaniX
01-25-2012, 01:42 PM
You can use a 12V or 24V as long as the power supply can deliver the current. The guy in the video is charging at 3C or 15A for a 6S 500mAh pack which is not recommended as good practice.
Drax21
01-25-2012, 02:10 PM
Yeah I always have plenty of time on my hands so i charge at 1c
veejo
01-25-2012, 06:06 PM
The DC chargers have inverts in them to step up the voltage and then recify, so if you have the 24V supply already, great, but I wouldn't buy one specifically and expect a different result. Most chargers will go to 18V input, so if you were going to buy a new power supply stick with 12/13.8V as it will give you the broadest selection of chargers to use in the future.
Yes, I also only charge on 1C .... patience ..... we are not born with it, we learn it.
That is also why 1 run 2 chargers off 1 powersupply (charge 2 batts at once at 1C), and they now make quad chargers which sell like hot cakes so you can gently charge 4 packs at once. At 1C who needs a temp probe ????
