View Full Version : Seaking 120 vs Hydra 120
worriedsick4u
01-24-2012, 02:38 PM
I'm putting a Neu 1509 1y in my pickle and was gonna use a hydra 120 but can't seem to find one anywhere. Is the seaking 120 just as good? I know I've asked alot of questions lately and appreciate the help you guys have given me. So if my questions seem stupid or repetitive it's because I have no friggin idea what I'm doing. I'm having alot of fun learning. Thanks again.
Diegoboy
01-24-2012, 02:45 PM
Will this be a 4S (14.8v) boat?
worriedsick4u
01-24-2012, 02:47 PM
Yes. Its that Pickle you helped me on yesterday. BTW Thanks for your guidance.
Diegoboy
01-24-2012, 02:50 PM
The seaking 120 should work, but I'd like to use the 180A (http://www.offshoreelectrics.com/proddetail.php?prod=ker-seaking-180) because I like to have the headroom.
I ran the Neu 1512 2D on 4S in a 24" Fiberglass hydro and a seaking 120a. the ESC blew the caps but survived the ordeal. If you go with the 120a add a cap bank (http://www.offshoreelectrics.com/proddetail.php?prod=etti-e035-lv&cat=136)for insurance.
Keep in mind that my Neu 1512 2D has a max surge watts of 2000
...and your 1509 1Y has a max surge watts of 1500 so it shouldn't punish your esc as much as mine did
worriedsick4u
01-24-2012, 02:54 PM
Thank you.
D. Newland
The 1509 1Y is a 2S motor. Maybe 3S, but not 4S. It's 3600 Kv.
I use that motor in my N-2 Offshore boat, 2S 10,000 MAh packs and X442 prop. It's an 80-90 amp setup.
worriedsick4u
01-24-2012, 02:57 PM
Here's the part that confuses me. I plan on using 2-2s 5000mah batteries. So not knowing any better I'm assuming thats 4s? Thanks guys for helping me out.
Diegoboy
01-24-2012, 02:58 PM
Good eye David, I saw it as 2600kV. I guess I shouldn't answer postswhile driving. :doh:
Diegoboy
01-24-2012, 02:59 PM
it will be 2S in parallel or 4S in series
worriedsick4u
01-24-2012, 03:01 PM
So i'm taking it D Smock when he used this setup he ran it 2s in parallel
worriedsick4u
01-24-2012, 03:03 PM
Just checked his thread. Yes. 2s2p. Got it. Thanks again. You've been alot of help. Now pay attention to the road ahead. Your help is valuable.
Diegoboy
01-24-2012, 03:05 PM
series vs parallel
68857
worriedsick4u
01-24-2012, 03:09 PM
Now I get it. Need to do some soldering. 5.5 Bullets over Deans?
Diegoboy
01-24-2012, 03:29 PM
Yes 5.5 bullets
Drax21
Yes definitely
68858
Diegoboy
01-24-2012, 03:35 PM
As D newland said, the 1509 1y has a kV too high for 4S
Maybe a 1415 1Y (http://www.offshoreelectrics.com/proddetail.php?prod=neu-1415&cat=117)
worriedsick4u
01-24-2012, 03:37 PM
Thanks. I think I'm all set. Saw that a member makes 5.5 bullet parallel adapters. Save me some work.
D. Newland
01-24-2012, 03:57 PM
Sounds like you already bought the motor...??
If not, you will be happier going with a 4S setup over a 2S setup. If you go with the 1509 2Y motor, it has half of the Kv as the 1Y and would be considered a 4S motor. 4S1P. It's safer on the ESC to go with more voltage rather than more amps to achieve your wattage output goals. 2S setups are typically amp hogs.
Anytime you have a choice to go with higher voltage vs. higher amps, go with the higher voltage setup.
worriedsick4u
01-24-2012, 04:19 PM
Yes. Purchased it last night. I was going by D. Smocks thread and wanted to put what he used in the same boat. Could not find anyone selling the Hydra 120. So I was concerned about the seaking being compatible. This stuff is confusing but you guys have helped alot. So voltage over amps always.
First boat I modified was a Miss Geico. Took out the motor and esc and put in a Leopard 4082 and seaking 180 on 8s (not knowing what the hell I was doing and the 2-4s batteries barely fit). Friggin thing flys. Flipped it several times until I figured you gotta lower the strut to keep it in the water. I'm in florida so swimming after it was no problem. Bought a Stiletto and put a hook on it. My retrieval boat. Busted three flex cables on the Geico already. Broke right where cable meets steel. Got a lake in the back yard. So access to do my thing is easy. Thanks again for your help
