View Full Version : Prop options on a 33" DF
sigelitest
01-22-2012, 05:45 PM
I oopsed it is a 36 not a 33
Looking for a prop size on a DF 36"
Using a leo 5692 1340Kv
5s single 5000ma 40c pack
200a SF ESsc.
I want to get some speed out of it and not melt the pack :flashfire:
01-22-2012, 05:50 PM
I have no personal experience with the 5692 motor, but if it performs as the specs say it should, start with an x450. That should get you into the mid/high 40s if the boat is trimmed well. You may be able to go up to an x648 but be careful....
sigelitest
01-22-2012, 06:11 PM
if i could get two packs in there what do u think on prop and speed
oscarel
01-22-2012, 07:47 PM
Wow, that's a lot of motor for a 36" boat. I've got the Hobbyking version that I'm putting in a Stryker f41 and I was going to start with a X455. Have you purchased the motor yet? Have you seen the prices on these http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18848?
iamandrew
01-22-2012, 08:08 PM
Ive ordered one, waiting on one of the 1700KV ones
ive got a few 40C 4s and 5S packs, so was going to use them in a 1M hull, hopefully it will work!
sigelitest
01-22-2012, 10:53 PM
I looked at the HK motor it looks nice. Already got this one Installed with home made motor mounts
687746877568776
should i go 6s 1p or 5s 2p and what prop for that setup i want to get it above 60 with out blowing the pack
fluid made me see that 1 5s pack aint gona cut it
Make-a-Wake
01-22-2012, 11:41 PM
On 5s that motor can spin alot of prop. An x455 or x452/3 should be right in the zone for you. As Fluid mentioned though, an x450 would be a good place to start safely.
