View Full Version : HELP! Need Excel Spreadsheet for Octura and Others
Meniscus
01-22-2012, 03:15 PM
So I have some fancy calculators I'm looking to make available for all to use. At the moment, I only have it built for 40-50 props and have to do add each additional by hand. What I need is an Excel spreadsheet including prop #, diameter, pitch, total pitch, etc. Of course for the Octura props, I know the diameter and pitch, but it would help eliminate having to enter each by hand. Then I can map for most of the common motors and to each type of hull to calculate speed.
Anyway, if you know where I can find the Excel Spreadsheet file for Octura or other props, it would be greatly appreciated and eliminate a lot of time.
Diegoboy
01-26-2012, 01:59 AM
I'm not sure if this is what you want but I assembled THIS (http://www.diegoboy.com/misc/Props.xls ) for you.
Octura on the top part, ABC on the bottom
Meniscus
01-26-2012, 10:07 AM
Danny, that's awesome! Did you end up pulling source html, then port over the tables? I'll work with this list and then add for other manufacturers. This has saved me a lot of time.
Diegoboy
01-26-2012, 11:39 AM
I converted the PDF's to excel, (octura & abc) created a new blank spreadsheet, Copied, Pasted, and typed till my fingers hurt. Then voila!
Diegoboy
01-26-2012, 12:31 PM
The reason for the spacing is to have a header at the top of every "printed" page (as opposed to flipping pages to see what the column represents)
