View Full Version : turnigy t600+ 42" boat?
iridebikes247
12-15-2011, 11:04 PM
I am currently working on an mrp 42" fountain project and I was thinking about running a turnigy t600 1400kv motor along with a 150a esc on 4s lipo power. Would this setup be sufficient for a boat in the 42" range? thanks
Make-a-Wake
12-15-2011, 11:09 PM
If its the ultra light MRP hull im thinking of it should work fine................you could actually go 6s if the motor can handle it which i think it can.
6BOOST
12-16-2011, 03:01 AM
Well they run the 880kv motor on 10s all day every day and some EDF guys have done over 18 months of flying at this including some who have pushed 12s on the 880, so 6s should be well within the rpm limitations of this motor. Watch the temps tho, HV seems to run cooler so the 1400 on 6s might run hotter. It should work fine in this hull, the EDF guys are seeing over 4kw.
6BOOST
