View Full Version : What is the fastest mini these days? Cast your vote!
jlanders001
12-13-2011, 10:37 PM
I'm taking a poll on the fastest mini out there under 17" Consider acceleration and top speed.
Please cast your vote. Name the make and model of the boat you think is the fastest around.
Chuck E Cheese
12-14-2011, 11:05 AM
here are a couple of mine. the gecko and rigger. i actually rebuilt the gecko to slow it down and make it more user friendly.
http://www.youtube.com/watch?v=Dd_gN5XZTvc&list=UUBTwFS2Bwb6LezkyjHkDjbg&feature=plcp mhz gecko
http://www.youtube.com/watch?v=2REhnHgSUYo&list=UUBTwFS2Bwb6LezkyjHkDjbg&feature=plcp scratch built rigger (jae micro prototype)
Alexgar
12-14-2011, 03:52 PM
i love my minicat velocity 450 outrunner 2500kv on 4s x435 cut down to 32mm getting sv27(stock speed and very stable, my renegade doesnt run far behind it with 400 outrunner 3200kv 3s on a 431 or 531 oct but not as fast due to not being half as stable(spends alot ov time upside down)
sailr
12-19-2011, 01:52 PM
The new GII Micro Hydro runs 42-45mph out of the box!
martin
12-19-2011, 02:49 PM
if were looking at top end speed, all round stability & unbelievable cornering them i believe theirs nothing comes close to a JAE Mini Sprint. Martin.
zue
12-19-2011, 04:10 PM
Mini Hydro whit Thenshiock 1030/10, 3Slipo http://www.youtube.com/watch?v=2Nbo55N4DVg&feature=related (far level)
http://www.youtube.com/watch?v=QNlHF1L-b6g&feature=player_embedded (left)
properchopper
12-20-2011, 12:55 AM
Is this Eco mini fast enough for you ?
http://www.youtube.com/watch?feature=player_embedded&v=CGhMsoEDdlg
jlanders001
12-20-2011, 01:03 AM
That JAE is looking very good. I may go with that. Cornering is really something! I don't see how it stays stuck to the water during fast turns like that!
Does Mini Cat still make the Micro Bat? According to the reviews back in 2008 or so the Micro Bat was a good bit faster than the Micro Hydro ever was. You could drop in a 4S battery with the upgraded motor and ESC! That’s just plain sick. I was thinking about that boat when I first posted this thread.
Any other suggestions?
NativePaul
12-20-2011, 05:19 AM
JAE minisprint is a great hull but its over 18" if built to the stock kit, I didn't realise this as its quoted as 17" on the Zipkits site and I had to cut about 1/2 an inch off the tips of my sponsons to get mine into the 450mm (17.75") max mini classes here.
badag98
12-20-2011, 11:43 AM
Proper what have you done to that thing it hauls!! what are you running in it?
Jeepers
12-20-2011, 12:06 PM
I don't believe that's Tony's unless he moved from CA to Europe.
properchopper
12-20-2011, 12:31 PM
Yah, Das iz mine fasten boot. Iss berry quicken in straitz bot ze turnz iz vary toof ..
[ Billy, I just pilfered the Vid from RRR; not my boat]
NativePaul
12-21-2011, 12:04 AM
That's neither Mini nor ECO, FYI this is Mini ECO Expert (http://www.youtube.com/watch?v=ucp-gHEnRG8&feature=related) (the faster of the 2 Mini ECO classes) at the same event.
jlanders001
12-24-2011, 01:49 AM
So Chuck, what ESC and motor are you running in that rigger? I'm thinking I'll probably go with the Mini Sprirt.
1. What ESC and motor is considered to be the fastest on 3S that will still fit in one of these?
2. Do people add esc and motor water cooling to mini riggers?
Thanks,
JTL
martin
12-24-2011, 10:04 AM
This is my Mini Sprint with $12 Mystery 3800kv outrunner motor on 3s with 60 amp cheapo esc.
http://www.youtube.com/watch?v=nOUlQEGC8lg
Chuck E Cheese
12-24-2011, 12:06 PM
mine was using a mamba 25 and df400 from the renegade rigger..... prop work and weight is key on
these little riggers....
sailr
12-24-2011, 01:09 PM
Only 7 days to go to get 15% off purchase of $100 or more at Mini Cat Racing USA! PM me for details. We have the Mini ECO, Starship, Micro Hydro, and Velocity Cat in stock!
Brushless55
12-24-2011, 07:17 PM
Wow is that cool!
jlanders001
12-25-2011, 12:45 AM
What happened to the Micro-Bat?
jlanders001
12-25-2011, 01:49 AM
What brand was the ESC that you used?
martin
12-25-2011, 04:23 PM
The esc was an RC Max 60amp watercooled which was £13 or around $20, i got it from giantcod.co.uk. I believe these esc are the same as the many cheapo different badge ones that are on Ebay under various names.
Mattwarner
12-25-2011, 05:21 PM
Does anyone in the uk stock the mini sprint, I want one now seeing this!!
martin
12-25-2011, 06:41 PM
You have to get them from Zippkits in the US, i believe they are doing them for $89 at the moment down from $109. When i got mine shipping was around $36 to the UK + vat & import duty. In total i think it cost me around £100 for the kit by the time i paid everything.
martin
12-25-2011, 06:49 PM
If your going to push the speeds on the kit your going to have to do some mods, the rudder bracket is part of the ply side & you need to alter this to a full alloy bracket otherwise you tear the rudder off in turns ( ask me how i found this out ). The design construction was not done to suit these loads & speeds. Also you need to upgrade the carbon boom tubes which are 3/16" o/d hollow to 6mm solid carbon (again ask me how i know). Another must is bolt the turn fin right through the sponson otherwise youll tear the screws out of the sponson in the G force in turns.
larryrose11
12-26-2011, 10:11 AM
A moderator should take Martins notes / recommendations and make a 'sticky' for the JAE mini sprint, as a lot of people on here want to go crAzY fast. else, they will get lost.
FYI, a 3/16 of an inch = 4.7625 mm on the carbon booms.
BILL OXIDEAN
12-26-2011, 10:48 AM
BBY Racing designs by far the fastest, most stable and reliable mini boats in the world hands down.
Randy has all the stats, ill get him to post when he wakes.
martin
12-26-2011, 11:33 AM
The original boom tubes are 3/16 o/d tubes which will break if you push speeds, in the UK imperial size tubes or solid rod are not available only metric. Thats way i went to 6mm o/d solid carbon rod which then makes repacment easy without having to order from the US. Even on the JAE 21 fe during the build i change to metric size carbon boom tubes ie i fit 8mm & not 5/16".
martin
12-26-2011, 11:39 AM
BBY does make some excellent boats but you wont get a boat complete (less motor & electrics )with all hardware for around $100, yes you have to build the kit which is dead simple & great fun to build.
martin
12-26-2011, 11:44 AM
The 6mm = .236" solid boom tubes were chosen for their larger diameter + solid rod for the increase in strength.
larryrose11
12-26-2011, 12:40 PM
BILL OXIDEAN,
I have seen the BBY Lift-master rigger series only on this site. Awesome looking / running boat.
Randy had a pic of a small lift master in another build (the pink lift-master build)
Can you tell us more about this smaller of the lift-masters? Will it become available to the public, or at lease OSE members ;)
BILL OXIDEAN
12-26-2011, 12:47 PM
BILL OXIDEAN,
Happy holidays!
Randy has about 6-versions of the lift master from what I understand.
One benefit to dealing with a MFGR like BBY is he will build anything you ask for.
If you saw a smaller one, he will gladly build it for you. in fact, any combination of tub and sponson in the lift master series can be mixed and matched to a customer's desire.
I hope this answers your questions.
larryrose11
12-26-2011, 12:53 PM
BILL OXIDEAN,
Do you know of a website where he catalogs these various designs, or should I just contact him directly?
jlanders001
12-28-2011, 12:39 AM
Where do you buy these again? Link?
jlanders001
12-28-2011, 12:45 AM
So you CAN add water cooling to a Mini Sprint? I had doubts due to lack of space etc. Rudder pick up?
By the way, what's the biggest 3S battery that will fit in a Mini Sprint?
martin
12-28-2011, 04:37 PM
In the UK you can get carbon rod & tube from model shops, if they dont stock it just get them to order what you want. Both Ripmax & J Perkins import the carbon, thats were model shops get theirs from but you cant buy direct from them though you have to go through model shops. Look up Ripmax & J Perkins % all the carbons on their sites around £6-7 a metre length. Martin.
martin
12-28-2011, 04:45 PM
The rudder with the kit has a water pick up already so you just need to add water line to tub. The largest size lipo i found you could get in was 2200mah as you are restricted on length that you can get in. When i built mine i raised the deck of the tube up arounf 6mm so as to get 3s in along with a bigger water cooled esc. Ive since moded the tub again raising up further as im going to use a Leopard 2860 motor with 120amp esc & poss 4s. I think its going to be quite quick hopefully. Martin.
RandyatBBY
12-29-2011, 02:20 AM
Hear is a few pictures from BBY
http://img341.imageshack.us/img341/8761/img0257nd8.jpg (http://imageshack.us/photo/my-images/341/img0257nd8.jpg/)
this boat went 84MPH
http://img48.imageshack.us/img48/4794/img094811ro3.jpg (http://imageshack.us/photo/my-images/48/img094811ro3.jpg/)
Uploaded with ImageShack.us (http://imageshack.us)
click on the pictures and you will find more of my work, you can call me info on front of my web site.
http://www.bbyracing.com/elecmicrohulls.asp
Mattwarner
12-29-2011, 06:57 AM
Nice!! :rockon2:
