View Full Version : Seaking 120amp esc v HV esc
martin
12-09-2011, 05:25 AM
If you use a Seaking 120amp esc on a Leopard 3674 0n 4s do you go for a lower amp if you then go for an HV esc or should you still go for the same amperage esc in HV. Thank you.
siberianhusky
12-09-2011, 06:08 AM
Same, as you're not actually changing the amperage. The voltage rating is the difference in the esc not the amperage.
If you're looking for more headroom you'd want to look at a 180 or 200 amp LV esc instead of a lower or same amp HV one.
