View Full Version : 5 Blade Cleavers?
Mattwarner
12-07-2011, 06:25 AM
These look really cool but i cant see anyone using them? Do they just not work as well as a 2 blade?
http://www.prop-shop.co.uk/index.php?id=25§ion=services&sub_section=products&product_type=25
egneg
12-07-2011, 08:28 AM
They work but you need a very strong high rpm motor, check with graill for details.
Boaterguy
12-19-2011, 03:57 PM
they also cavitate more.
they are used in big (full size) cats for a reason i do not specifically know (nor is it relevant in this explanation)
think of the space between each blade on a full size boat with a 5 blade prop, it is usually about 6 inches.
think of it on that prop you linked to, it's more like 1/4-1/2", so the amount of time the water has to close back in (theoretically) is very little, especially at high rpm's, so cavitation is high and efficiency drops (plus they are a pain in the arse to balance)
I will be using the 5 blades from prop shop for my custom mhz twin saw boat.. Takes alot of work and they need big power.... Let you know how it goes.
If your scared of pushing the limits of components then stay well away.
cheers
12-19-2011, 06:23 PM
Multi-blade props have several advantages over two-bladed props. For the same blade area they have less diameter, so have less torque effect on the boat. One blade is almost always in the water so there is a smoother transmission of power to the water instead of the distinct two-thumps-per-rev of twin-bladed props.
They also have disadvantages. They are heavier and stress the hub/blade root area more, so there is a higher chance of throwing a blade. Their efficiency is lower because the previous blade has disturbed the water for the following blade. All surfacing props cavitate - that is how they provide their high thrust - but water with bubbles and currents doesn't allow the same 'smooth' cavitation to occur, reducing blade efficiency. They are also more difficult to balance and sharpen, and the choices of sizes is very limited. Too, cupping and adding pitch is very difficult with props having more than 3 blades. Serious SAW racers want to be able to fine-tune their props to that last mph, which is tough to do accurately.
For top SAW speeds two-bladed props are normally best, but depending on the power to be delivered the smaller diameter multi-bladed props have their place. Still, current fast SAW boats almost all use 2-bladed props.
Yes I remember way back when ski boat races all had outboards and 3 blade props, now they have their ass's handed to them buy turbo'd inboard big block chevs that ALL run multi blade prop's.. Funny how times change and records are made to be broken..
Guess it comes down to the "serious" saw guys and their testing?
egneg
12-20-2011, 08:35 AM
This is a pair of Prop Shop 8015/5's that I modded for graill to use on his cat the Platinum Princess. He said they were hit and miss as far as hooking up but when they did...
66054 66055
12-20-2011, 11:15 AM
The fastest propeller driven hydro through the measured km (220+ mph) is the Miss Budweiser, using a Dave Villwock 3-bladed prop. Even then, the propeller broke and the driver was lucky he was not seriously injured.
http://i44.tinypic.com/3503p0n.jpg
SAW runs are a lot different and more demanding than drag racing. Having to keep the prop together for 2 kms is problematic. Most don't realize this, but full-scale racing props running in surfacing mode get very hot! Hot enough to lose both temper and pitch. Even one of the best prop makers in the world (Villwock) has trouble meeting that challenge, see above.
66054 66055
Yeah i heard that,and was warned.. hence why alot of testing before the main event..
The 5's may be crap but it's worth a try.. Costing alot to get prepped though, hope they work...lol
66054 66055
Agreed'd the pitch they use is crazy and the tourqe is out of this world...
Alot different than 45 to 55 though rpm.... om tiny scale boats... you even need to calculate the water viscosity brfore final desicions...
12-20-2011, 08:27 PM
I am among other things a fluids engineer, and I can tell you that no R/C boat record holder "calculates" the water viscosity when making prop decisions. Reynolds number and density have more effect than "viscosity", but no software exists to quantify that effect anyway since surface tension has a disproportionate effect on R/C props; no one needs to do any 'calculation'.
It may surprise you to learn that the blade speed on R/C boats is far slower than on full-scale SAW boats. The tip speed on the Miss Budweiser's prop was around 550 mph, while that on a typical FE SAW boat is closer to 80 mph.
Tip speed may have something to do with diameter bud? Surprised....
And no one calculates viscosity..
I'm one and no of two others.
Thanks for the info though..
Cheers
Fluid when I meant viscosity I also meant a few factors like density etc..
Kind of like a fast pool and a slow pool at the Olympics. The density of salt versus fresh. Yet to own a title but have bought the equipment that has got the records and am upgrading components.. Stay tuned
Cheers
12-21-2011, 10:17 AM
And no one calculates viscosity...I'm one and no of two others.I think I said no record holder calculates viscosity. Viscosity is a measured value anyway, as is density, salinity, etc. Do you use an AntonParr 500, a Fann 35, or a Marsh Funnel to obtain your viscosity values? How you would use this subtile information for making a prop decision - when other factors like wind and waves have a much larger effect on speed - escapes me. You would need a large database of test results to make any practical use of viscosity measurements.
Regardless, good luck on your attempts. If I can assist in any way, just let me know. I've held a few SAW records myself....
Flying Scotsman
12-21-2011, 12:59 PM
As has been said before I find sharpening and ballancing a 3 bladed prop a real challenge never mind the other tricks of the trade in prop mangling.
Douggie
[QUOTE=Fluid;378412]I think I said no record holder calculates viscosity. Viscosity is a measured value anyway, as is density, salinity, etc. Do you use an AntonParr 500, a Fann 35, or a Marsh Funnel to obtain your viscosity values? How you would use this subtile information for making a prop decision - when other factors like wind and waves have a much larger effect on speed - escapes me. You would need a large database of test results to make any practical use of viscosity measurements.
No apparently thats a little old school, we use a brookfield DV-11+..Not that i claim to be able to operate it properly but my fellow racer has access to it at his place of work..
I suppose the saw events you have experience in are a little different to over here?? Maybe... Most of the time its glass and not in the salty choppy sea??
Wind and wave is an obvious factor but if you are looking for an edge then you need to up the ante.. Being a fluids engineer i imagine you would understand.. I'm a mere mechanical engineer that builds the trains we ride on.. Not the cordial we drink or the oil we put in our cars.. Cheers
Thankyou for your offer of help..
12-22-2011, 02:29 PM
Having access to the equipment and knowing what it is for are two entirely different things. I've used the Brookfield instruments for decades, and they are useless in characterizing Newtonian fluids like water. They use low and ultra-low shear rates - nothing like what a propeller sees - and are used to measure non-Newtonian fluids like paint and oil. The Anton Parr 500 is a cutting edge rheometer - but it too is useless in characterizing water. If you like doing mental gymnastics which result in no useful data, feel free.
SAW racing is what it is - smooth, rough or in between, whatever the conditions on race day. The difference between water with a very slight chop and glass smooth is at least 5 mph. Being a fluids engineer I'd rather spend time drinking a cordial than wasting time on fluid dynamics which have no practical end use in FE SAW racing.
Again good luck - really. I think you'll find that the time spent in trying to characterize tiny differences in water would be better utilized in actually testing the model and developing a database based upon performance rather than upon dubious math.
Fluid you have me all wrong, mental gymnastics is not my forte..
As for useless, guess proofs in the pudding, and by the way that machine is no dinosaur. Less than a few years old. The manufacturer is decades old.
Sometimes being wrong isn't that bad.
Have a great xmas
antslake
12-25-2011, 12:23 AM
You guys are funny!
LarrysDrifter
12-25-2011, 12:54 AM
Fluid may seem to be stern at times, but, more often than not we all sound (read) like as$holes. Its just the nature of reading someones typed posts. I dont know him on a personal level at all, but I can assure you he is a very smart and knowledgable man among many others here. Im no engineer of anything, Im a pipefitter building and maintaining gas stations (on the petrolium aspect). I know nothing of fluid dynamics, but I do agree with Fluid. Id stick with testing of props and messing with hull adjustments such as hardware settings and center of gravity. I am no pro at FE , but my own personal claim was an 81 mph twin cat 32" L ran on 4s per side. The more I messed with it and the more props I tried, I finally got the speed I was looking for..on GPS, of course.
Yes I understand. Fluid is a wordsmith and can bamboozle alot of people.. There is no doubt fluid has a depth of knowledge that many would envy, hence his respect on this forum,,
Barry sheen was brilliant but alas developments evolved as did age and technology.
I still respect Barry, but doohan and stoner would kick his ass...
Merry xmas
LarrysDrifter
12-25-2011, 04:01 AM
Nevermind.
Steve-O
01-01-2012, 10:37 PM
Just out of curiosity: What is the viscosity of water at 70 degrees F. and how much would it have to change to make a prop change effective?
