Looking for a 1/4" bore x457/3 prop. Any ideas?
  • jlanders001
    • Nov 2011
    • 41
    Can anyone here tell me where I can buy a 1/4" bore Octura x457/3 prop preferably sharpened and balanced? I can only find 3/16" bores in that prop. I've searched and searched. Seems like it would be easy to find since you FE guys mention them pretty frequently.
    Is there a comparable prop from another company that would perform about the same as the x457/3?
    I don't suppose you could bore out a 3/16" to make it a 1/4". That sounds like a bad idea I guess.
    By the way this will be for a 51" FE w/ 2028.
    Thanks,
    JTL
    Been in RC for years. But have not tried all the types of boats.... YET!
    • 8012
    This prop is not available in 1/4" bore. Few props under 70mm are made with 1/4" bores. If you want to run that prop, or other 3/16" bore props, get a step-down stub shaft on a 1/4" flex cable.
    http://www.offshoreelectrics.com/pro...?prod=ose-1290
    • ManuelW
      • Oct 2010
      • 756
      Or if the hub is thick enough in diameter you may find someone who can make a 1/4" bore in it. I once had it done for me on a pair of Octura X457's and it worked. But it has to be done absolutely properly on a professional turning machine. Otherwise you'd have massive problems with unbalanced props due to a bore out of center.
      So when thinking about this, forget about making it at home with a drill. Even with the right equipment it may be tricky but it can be done.
      For a similar prop, recently I bought a pair of PropShop 5514/3 with 1/4" in SS. They might not be cheap but they already come with a 1/4" bore.
      Best regards,
      Manuel
      • ray schrauwen
        • 9471
        Prop shop 5714E, comes in 1/4" or 3/16" bore. I have one but it is not for sale, sorry.
        Nortavlag Bulc
        • ray schrauwen
          • 9471
          You must specify 1/4" or 3/16" bore.I got 1/4" when I wanted 3/16"
          Very nice prop and I "assume" the "E" is for electric.
          I would pass mine to you but, they need sharpening and I went a bit heavy on mine... might need to buy another.
          They will typically take $40 for an offer.
          Well balanced but, need sharpening & re-balance.
          Nortavlag Bulc
