View Full Version : Flex Cable Crucible
FloatDaBoat
12-05-2011, 07:39 PM
Here’s how I tin the ends of my flex cables: Purchased an iron pipe cap plug, ground the threads off, clamped the square end in a vise, added chunks of 95% Tin/5% Antimony Plumber’s Solder, heated with a Propane Torch, submerged the rosin coated cable ends into the molten solder. Works like a Champ!!!
See DaPic . . . .
siberianhusky
12-06-2011, 06:53 AM
Great idea! I haven't thought of a solder pot in years! I've been using my mig welder for a while on cables now, takes about 2 seconds and works great as well.
FloatDaBoat
12-06-2011, 10:08 PM
Must be nice! I don’t even have a place to store a welder, even if I could afford one.
This is the neatest idea to come "out of the blue" that I've seen! I've struggled with tinning drive cable ends for years and never thought of this great "old school" solution.
01-24-2012, 02:11 PM
Its a neat idea.
have you tried just a soldering iron? I use a weller 80 on upto and including .187 cable with no issues what so ever. The weller 80 is marketed to the stained glass market and holds a ton of heat.
Drax21
01-24-2012, 03:32 PM
Its a neat idea.
I also use the Weller 80. It's great!
martin
01-25-2012, 04:04 PM
[QUOTE=Steven Vaccaro;387219]Its a neat idea.
have you tried just a soldering iron? I use a weller 80 on upto and including .187 cable with no issues what so ever. The weller 80 is marketed to the stained glass market and holds a ton of heat.[/QUOTE
Do you find the Weller 80 good for bullet plugs as well, i was looking at getting one myself.
Drax21
01-25-2012, 04:12 PM
I use the weller 80 watt with 5.5 and 6mm bullets all the time including silver solder. It does the job every time.
SirBudman32
01-25-2012, 04:19 PM
I got one from harbor freight 180 watt and does them with no problem. And for only 12 dollars, cant go wrong
01-25-2012, 06:39 PM
Yes they work quite well on the plugs also. the iron is large so it takes some getting used to.
DINO7
01-26-2012, 10:30 AM
nice mini soldering pot
http://www.dealextreme.com/p/150w-temperature-controlled-soldering-pot-blue-golden-220v-48761
worriedsick4u
01-26-2012, 03:21 PM
So is silver solder best for tinning flex cables? Flux needed?
rcboatmanwithkids2880
01-27-2012, 06:18 PM
Hi Guy's ,
That Soldering Unit Pot has an Austtralian Power Plug on it , I thought we were the only ones using it. ???
Brad
Oz
sailr
01-27-2012, 06:37 PM
Do the Aussies use 250V or 110V power mains?
01-28-2012, 01:44 AM
Hi Salir ,
We use 240V .....
Brad
Oz
